I have a 1987 mustang gt and why dos it keep dieing after it been started for 30 mins? - Mustang Evolution
Old 12-11-2011, 08:15 PM   #1
It could be the TPS or IAC, clean or replace..
Ford Mustang IAC IAB - Solving your idle problemsDoes your idle rise and fall over and over again? Does your 'Stang stall when you come to a stop, or even when you put it in gear?
http://www.muscularmustangs.com/iac.php
imported_Bob is offline   Reply With Quote
Old 12-11-2011, 08:32 PM   #2
i will say possible blockage in fuel ine somewhere between tank and injection. start ththe car wait till the car is warm then try to floor it while it is idling and before it dies, if that doesnt work try a fuel cleaner. basically tip it into the tank before you fill it
Aethelhard is offline   Reply With Quote
Old 12-11-2011, 08:55 PM   #3
Clean or replace the Idle Air Control valve. It's positioned in front of the throttle body. Hasa two wire electrical hook-up.
Ephron is offline   Reply With Quote
Old 12-11-2011, 08:58 PM   #4
check for a bad cat. internal restriction in your exaust sys will generate excessive back pressure and cause your motor to quit. good luck
bourke is offline   Reply With Quote
Old 12-11-2011, 09:57 PM   #5
Coil pack's toast. Replace it with one from the wrecker, should be about 25$.
Jayar is offline   Reply With Quote
1987 mustang
09:40 AM
