Why does my fox body mustang heat up after I drive it for a while? - Mustang Evolution
Old 12-15-2011, 05:30 AM   #1
My temp gauge goes almost all the way up to the top then goes down below the half way mark. I just got checked for leaks and I have none and the antifreeze levels are good. 1992 Mustang GT. I have an aluminum radiator by the way with all new hoses.
Edensaw is offline   Reply With Quote
Old 12-15-2011, 05:58 AM   #2
Fan clutch going bad or sticking thermostat. My '92 goes one past the halfway point then returns to the middle of the gauge when the electric fan kicks on
howie is offline   Reply With Quote
Old 12-15-2011, 06:51 AM   #3
Make sure your thermometer is still good, sometimes they stick until too high temps and then release after that. It should be cheap enough go ahead and buy a new one and put it in.
brewer is offline   Reply With Quote
Old 12-15-2011, 06:55 AM   #4
maybe you need a new thermostat or you have air in the line and its not a bad leaky head gasket
wakiza is offline   Reply With Quote
fox body
08:21 AM
