Where can I add transmission fluid to a 1989 Mustang GT? - Mustang Evolution
Old 12-16-2011, 06:30 AM   #1
My tranny level is below the hash marks on the dip stick.
corren is offline   Reply With Quote
Old 12-16-2011, 07:15 AM   #2
get a funnel and add fluid through the dipstick tube
fuller is offline   Reply With Quote
Old 12-16-2011, 07:46 AM   #3
well if its automatic transmission, you can add it through the dip stick under the hood with a funnel, but if its a manual transmission, then you can do it two ways, you can add it through the top, where you disassemble the shifter reach where the shifter mounts on to the tranny and just pour it in there or you can go under your car, your transmission has 2 plugs, vertically alligned and the upper plug is where you pour it in and you put your finger in to see if its full and the bottom one is just for a drain, just in case you over fill.
ephrayim is offline   Reply With Quote
Old 12-16-2011, 08:34 AM   #4
if it,s below the cross sections you add enough fluid to bring it up into the cross section or at the full mark.
aodha is offline   Reply With Quote
1989 mustang
02:33 PM
