Would a 4cyl radiator work for a 8cyl? - Mustang Evolution
Old 12-17-2011, 08:30 AM   #1
I have a 1991 mustang and it was a 2.3 and i put a 302 in it, Will the 2.3 radiator work or will it over heat?
howahkan is offline   Reply With Quote
Old 12-17-2011, 08:36 AM   #2
There were 2 different factory radiators commonly used in these Mustangs. One was smaller, top / bottom tank design used on early 4 cylinder cars, usually mounted using a sheet metal extension to get the radiator closer to the engine. The second was a 2 core cross flow design. The cross flow design will work on a mild 302 if it is in decent shape. Donít even try the smaller it isnít big enough. For any type of high performance application get a new 3-core copper or aluminum radiator. Also always run a thermostat - engines will have dramatically less wear and perform better at the correct operating temperature.
kealy is offline   Reply With Quote
Old 12-17-2011, 09:15 AM   #3
drrrrr errrrrrrrr a 4 cylinder wouldnt need as much cooling as a 8 cylinder, but a 8 cylinder would need alot more, so the point is, no it wont, usually a radiator for a 8 cylinder car is much bigger than a 4 cylinder radiator.
good luck
Aethelhard is offline   Reply With Quote
Old 12-17-2011, 09:30 AM   #4
No it wont work it will overheat the 8 cyl engine the 4 cyl radiator has half the cores and passes the larger radiator has.
Waldemar is offline   Reply With Quote
11:44 PM
