Estimate horsepower from a 302? - Mustang Evolution
Old 12-18-2011, 05:45 PM   #1
1984 mustang gt 302 .30 over comp cam dome pistons edelbrock rpm intake 600 4 brrl carb bbk shorty headers 3" dual H flowmaster exhaust looking for a close guess on horsepower i know there 175 hp stock also was wondering the weight for a manual mustang
thanks.
Renfrid is offline   Reply With Quote
Old 12-18-2011, 06:30 PM   #2
It all depends on the C.R. of the domed pistons, that's were the hp is at. weight of a v8 coupe is 3150 lbs..
garvyn is offline   Reply With Quote
Old 12-18-2011, 07:15 PM   #3
I think the estimate of 250 hp is close..maybe a bit on the high side. Didn't say what kind of heads you're running, but the poster that mentioned the heads being a bottleneck is right on. The stock Ford heads are very restrictive. Better flowing heads are a "must have" for the Mustang. The Edelbrock RPM intake has a usable powerband of 1500-6500 if I'm not mistaken, is this matched with other parts on the car?
The weight for a 1984 Mustang hatch is about 3000 lbs. Depends on the variant.
Vaiveahtoish is offline   Reply With Quote
Old 12-18-2011, 07:32 PM   #4
250hp respectively.
The biggest bottleneck for your motor is the heads, as you are pre HO. Any heads are better than the stock ones on there right now.
Look through Summit Racing mags and a good reliable head is the GT40 aluminum one for the price.
You have a good choice on the rest of the parts, but once you unlock the breathing potential you will gain about 80hp right there.
Have fun and I believe your looking at 2400lbs
innis is offline   Reply With Quote
Old 12-18-2011, 08:00 PM   #5
my guess would be about 300. most people way over estimate horse power. might go to the drag strip and get some time slips. with et and trap speed you can calculate horse power with out dyno
drogo is offline   Reply With Quote
Old 12-18-2011, 08:25 PM   #6
I would guesstimate about 220-230ish. If you're using the stock heads and cam, you're creating a bottleneck.
edoardo is offline   Reply With Quote
Old 12-18-2011, 08:52 PM   #7
have it dyno tested
Orin is offline   Reply With Quote
12:03 PM
