My 1987 mustang 5.0 LX Dash cluster? - Mustang Evolution
Old 12-19-2011, 10:15 AM   #1
The dash cluster, the tachometer and oil pressure Gages are the only ones that work... do you think i should have someone install a new one, or try to track each one down and fix it.
darwin is offline   Reply With Quote
Old 12-19-2011, 10:36 AM   #2
Oil pressure sensor is on the front of the engine, on the driver's side, kind of off the timing chain cover. Get the sensor replaced & might fix the problem. The factory tach is run off the coil, so if the coil is bad, she won't run. There could be a fuse in the circuit, tho ..... Anything else electrical around there not working ???
Ardley is offline   Reply With Quote
1987 mustang
11:32 AM
