Gas guzzlin 5.0 - Mustang Evolution
Old 06-19-2008, 05:58 PM   #1
Angry Gas guzzlin 5.0
Well, here we go again. No power, and burnin lots of fuel. Does anyone know what makes a eec-iv speed density system go into closed loop control, is it temp or just after a certain period of time. My o2 sensors are reading super rich, but I don't think the computer is trying to compensate for it. All my electrical connections check out, and the computer isn't throwing any codes. 4 MILES PER GALLON, @ $5.00 a gallon, do the math, I NEED HELP!
79Bronco5L is offline   Reply With Quote
Old 06-19-2008, 11:57 PM   #2
MonteCitan's Avatar
Re: Gas guzzlin 5.0
Check the MAP sensor and test the TP sensor...
MAF could be dying, too - that is assuming you've done the EFI swap
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-20-2008, 06:36 AM   #3
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: Gas guzzlin 5.0
lol my 5.0 burns **** loads of gas.... and is super hot... but that is prolly because of the blower...
Cajun JungleBoy is offline   Reply With Quote
Old 06-20-2008, 07:48 PM   #4
Scut95's Avatar
Re: Gas guzzlin 5.0
I thought my car was running really hot, i threw a mechnical gauge in and found it was running between 190-210...the fan kicks on at 210, the stock gauge is up in the upper end towards the H FYI....the gas is probably the blower, boost is a great thing except for gas milage haha
Old 06-20-2008, 08:29 PM   #5
Re: Gas guzzlin 5.0
Been there, tried that. Thanks for the input, though. Think its almost time for a carb!
Old 01-14-2011, 12:39 AM   #6
94 Mustang GT's Avatar
Re: Gas guzzlin 5.0
Time has nothing to do with when it will go into closed loop. Its temp with other factors! but your o2 cant be reading super rich if its not setting any codes! what i can think of is that its throwing extra gas in to cool the engine but i dont think it would do that if its only at 210! And hopefully by now you fixed the issue!! lol if so what was the issue???
94 Mustang GT is offline   Reply With Quote
Old 01-14-2011, 10:18 PM   #7
Titus Wadicus
svtlx's Avatar
Re: Gas guzzlin 5.0
where da fuk r all these old threads cumn from????
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-14-2011, 10:31 PM   #8
Re: Gas guzzlin 5.0
hahahaha. I like to read the old threads and see what people did to solve their question! lol
Old 01-16-2011, 10:49 AM   #9
ibleedblue65's Avatar
Lol. Its possible the computer its trying to compensate for the rich condition but can't. Leaking injector or fuel pressure too high.
ibleedblue65 is offline   Reply With Quote
02:37 PM
