Car question. 1983 mustang 5.0? - Mustang Evolution
Old 12-20-2011, 05:30 PM   #1
Ok I just bought a 1983 mustang GLX convertable.
I am now interested in tuning it up.
I need suggestions, it has a stock 5.0 302 H.O. And a single flowmaster exhaust which i want to get a Dual for it.
What should i throw in this vehicle to make it the best it will be.
Buddy told me to throw shorty ceramic headers? Tell me if this is a good idea.
Please give me name parts, prices, and where to find them.
Thanks a bunch to all you other Horse Lovers.
gregg is offline   Reply With Quote
Old 12-20-2011, 06:26 PM   #2
Ok, from reading Shauns comment, I'm not so sure I'd pay him to touch my car. There's a few misnomers he mentioned. Like single exhaust making more power than dual. That depends more on the layout than anything. Or the 1-1/2" headers.
Short headers are a waste of money. If you want power, long tubes are the only way to go. Also, for a 302, 1-5/8 are a better overall size, as would a dual 2.5" exhaust. The best modifications you can do though, will be a good intake, carb, and a set of good heads. AFR 165cc heads, an edelbrock RPM manifold and 650cfm carb would really wake that car up. All can be found at Summitracing.com or jegs.com. Not sure of prices offhand, but they are well worth the price. The other thing I would suggest, before adding any power, or changing anything for acceleration, is to add a set of subframe connectors. Mustangs are notoriously flimsy chassis, and convertibles are even worse, so at a minimum do the subframe connectors. If you want to make more than 250-300hp, I would do at a minimum a 6 point rollbar as well. Upgrading the rear control arms and springs would be worth it too.
Hanan is offline   Reply With Quote
Old 12-20-2011, 06:48 PM   #3
Single exhausts will out HP and out Torque duals below 7,000 RPM. FYI: A single 3 inch exhaust with a 3 inch flowmaster and clean turns throughout, will support well over 350 HP.
Shorty Headers will cost you torque at streetable RPM ranges. Another area to kill things is by header tube diameter. Stick with a 1 1/2 inch header primary pipe diameter. The only exception would be a step header with the primary starting a 1 1/2 and stepping up to a 1 5/8. Keep it simple and run a 1 1/2 inch primary.
Since I design and make cams, I can help you there. I'm also a full competition race engine builder and carb blue printer.
Cams are the engine's air flow governor. Until you change the cam, you are not going to change the engine's air flow capabilities or demands. Be advised that 302's are VERY sensitive to cam timing. A little goes a LONG way. And they accelerate much harder with 108 Lobe Separation Angle cams than 112's or 114's. Especially as you add more duration in an engine with less compression. 108's will also give you far more of that cam sound, if you are looking for that characteristic.
Also keep in mind that stepping up to 1.7 ratio rocker arms will most certainly cost you low RPM torque and idle vacuum when you install them on the exhaust valves specifically. They also change the rocker arm to valve tip contact/footprint which is known as rocker geometry. To correct that, you have to change pushrod length. And if the contact at the valve tip is off center much, it will side load the valve in the guide and eat valve guides for breakfast.
I am telling you the rocker arm info because the Mustang crowd is comprised of many younger people who seem to like to throw a bunch of bolt on parts on their engines in search of cheap and easy performance gains. But most of the time, the don't see the whole picture. They'll care about peak numbers but don't realize what much of what they are about to do is going to do to their drivability or fuel mileage.
Your exhaust system needs to be set up for the HP out put of your engine. Stock cam, etc, I'd be messing with a 2 1/4 -2 1/2 single exhaust or you'll give up power with anything bigger. If you just HAVE to run duals, absolutely nothing bigger than 2 1/4 and an X pipe or you'll knock a TON of bottom end torque out of it that you'll NEVER make up for on the top end well enough to justify the loss on the bottom end.
Carb tuning is also where you can find some numbers and mileage to boot. That factory carb likely has some very high signal amplification rates on the boosters. And that's a very good thing. Fuel needs to vaporize in order to burn fast and make peak cylinder pressures early. Therefore, don't simply go out there and throw on a bigger CFM carb because CFM is only half the story. Like I said, if the carb does a poor job of shearing the fuel, it does not matter how well it flows because if the fuel is not vaporized well, the manners, mileage, power and response will all go in the toilet.
A 3.55 to 3.73 rear gear ratio is also a very nice set up for your car.
Email me at: camshaftshaun@gmail.com
buchanan is offline   Reply With Quote
1983 mustang
12:00 PM
