Mechanical fuel pumps works only sometimes? - Mustang Evolution
Old 12-20-2011, 10:30 PM   #1
Soemtimes it will work and sometimes not!?
I replaced the mechanical fuel pump on my 1979 mustang pace car 2.3l turbo cause i thought the fuel pump was bad cause it did nto work!
but even the new one sometimes will pull fuel but most of the time it does not?
Today i put the fuel line directly into a gas can of fuel and the breather into an empty pail, the pump worked and the car ran great, then i turned off the car after it ran about 3-4 minutes and then when to start it again then the fricken pump would nto work again and will not pull fuel now again!?
is this a bad pump even though its new? or is there something eles more serious wrong here?
macdaibhidh is offline   Reply With Quote
Old 12-20-2011, 11:26 PM   #2
You could have a leak between the tank and the pump.
imported_Matt is offline   Reply With Quote
Old 12-21-2011, 12:25 AM   #3
There is a plunger, or pushrod that drives the pump arm.
It's probably all gummed up and stuck.
imported_evan is offline   Reply With Quote
02:08 AM
