Chassis life on 1990 mustang? - Mustang Evolution
Old 12-22-2011, 02:45 AM   #1
How long will chassis last on a 1990 mustang gt 5.0 before I start seeing problems?
chesmu is offline   Reply With Quote
Old 12-22-2011, 03:01 AM   #2
Well, if by "chassis", you mean the unibody, they will last indefinitely if you keep them clean and make sure you don't have serious rust starting. Of course, they can always be repaired, but that gets expensive.
imported_Bob is offline   Reply With Quote
Old 12-22-2011, 03:41 AM   #3
Had to say without knowing where you reside......if you drive on highly salted roads, your floorpan life will me much shorter than my '92 out here in arid West Texas.. I've spent ample time under my Fox-bodies ('92 GT and the '86 Boss TBird) changing and adding suspension components and found very, very little rust...... You'll just have to examine your own ride for rust and corrosion. I would double-check the suspenion attachment points.
kolt is offline   Reply With Quote
Old 12-22-2011, 04:05 AM   #4
wit
Every time on beat on it, you twist it a little bit. Eventually the doors wont close or line up.
wit is offline   Reply With Quote
1990 mustang
03:59 AM
