How do i make both tires spin? - Mustang Evolution
Old 12-23-2011, 12:00 AM   #1
Okay so i have a little 1981 mustang with a engine swap. It's real easy to burn rubber, but when i do only the right one will spin. it makes me feel a little bit embarrassed. I would assume it has to do with the differential. What to do?
meturato is offline   Reply With Quote
Old 12-23-2011, 12:49 AM   #2
There is no smart way to do a stupid thing. You are thinking like a kid. You should feel more embarrassed about trying to spin your tires than you should about only one spinning.
boothe is offline   Reply With Quote
Old 12-23-2011, 01:14 AM   #3
Why do you need to spin both tires? Haven't you learned how to drive yet?
Truth be told, the tire with the least amount of resistance is getting all the power, and without a locking differential, that is going to happen because you are overpowering the available traction.
In low traction situations, the total torque delivered to each wheel is limited to the torque that is required to make the wheel with the least traction slip.
Stop trying to show off with a 30 year old car.
Ammi is offline   Reply With Quote
Old 12-23-2011, 01:24 AM   #4
If you plan on going all over town burning rubber I suggest you get ahold of a ford 9 inch rear end so mewhere with a pozzi trac differential in it and hook it up. It takes money or finding one in a junk yard by taliking to others who have parts laying around not doing nothing is what you need. It makes the rear end more squrrly than it is now but the car will launch better off the line I also suggest you make fiends with a guy in a used tire shop, or better yet get an after school job at a tire place or a
blakey is offline   Reply With Quote
Old 12-23-2011, 01:42 AM   #5
Detroit Locker differential, but can be expensive. You can do it another way....very cheap......weld your spider gears together in the differental. You first must clean all of the gear oil off any area to be welded (Spider Gears)! If you do it this way, don't tell your buddies because they might tease you for Jerry Riggin' it. It will spin both tires though, and may wear the tires a little faster in the rear.
Donny is offline   Reply With Quote
Old 12-23-2011, 01:48 AM   #6
Your right! You have to replace your differential. You can get one the cheapest at like Summit Racing or Jegs. It's called a posi-traction rear end. That will take care of that single leg burn out. The car will go faster to because it will "Hook-up" better. Hope I helped you out.
thornton is offline   Reply With Quote
Old 12-23-2011, 01:57 AM   #7
PUT THE HAND BREAK AND ASSALARATE
moketaveto is offline   Reply With Quote
Old 12-23-2011, 02:29 AM   #8
install a locker assembly into the differential
Rhys is offline   Reply With Quote
Old 12-23-2011, 02:41 AM   #9
if it isn't a posi rear end, then you are gonna have to install a locker in the rear end
charly is offline   Reply With Quote
02:54 AM
