MAF meter - Mustang Evolution
Old 06-22-2008, 11:46 AM   #1
MAF meter
i bought all the parts needed to convert my car to MAF from SD including a 70mm maf meter that is calibrated for stock 19lb injectors...my question is later down the road when the engine is built up a lil more i want to run 30lb injectors...can i still use my 70mm and just have it re-calibrated?
ProjectPunisher is offline   Reply With Quote
Old 06-22-2008, 08:01 PM   #2
Scut95's Avatar
Re: MAF meter
yes you can....as long as you're not making a lot of power and max out the MAF.....it takes quite a bit to do that though
Old 06-22-2008, 09:36 PM   #3
Re: MAF meter
ill be at 500 horses max when the project is over
Old 06-23-2008, 01:07 AM   #4
Scut95's Avatar
Re: MAF meter
that will be close if not over......when you go for your tune (and you should get a dyno tune when making that much power) they will be able to tell you if you maxed it out or not......im thinking with 500 horsepower you're going to have to run a 90mm....you can get one out of a Lightning
Old 06-23-2008, 03:04 PM   #5
Re: MAF meter
yea im defiently getting it dynoed when all that happpens...my boy owns a garage and he has a dyno so im all set there..ill prolly just upgrade to 90mm even if i dont have 2 just to be safe later on
Old 07-13-2008, 09:21 PM   #6
silverstangboy's Avatar
Re: MAF meter
with a dyno at your disposal, a programmable solution sure sounds nice, alot of options there
93 mustang notch
~450hp 331 stroker - Sold
Jerk-O-Meter 00vertstang The Bar 4 08-13-2005 12:17 PM
Auto Meter D-PIC Performance Meter Dom Pre-2005 V6 Mustang 15 01-07-2005 03:35 PM
09:29 PM
