| Seat Belts
I was in the process of removing seatbelts for repair and discovered a necessity for a torx socket. What's the size and type of bit/socket do I need? On a side note if anyone ever needs to take the rear seats out of they're foxbody convertible, be aware the two bolts holding the upper seat back in are at the bottom corners behind the cushion, you can't really pull it back without locking the bolt and ford engineers decided the bolts you can't see, can barely feel should be 10mm...
88 convertible
