Rebuild question - Mustang Evolution
Old 01-07-2013, 08:19 AM   #1
vettekiller's Avatar
Rebuild question
I am rebuilding my 302. The motor was not blown or messed up. I'm goin to fresh in it up and put new intake, heads and cam. Do I need to have the block machined ? Or can I just rering , gaskets.. etc . then reassemble ?
vettekiller is offline   Reply With Quote
Old 01-07-2013, 08:21 AM   #2
If you are putting new heads on and have the extra funds I would at least recommend having the block checked and possibly milled to ensure the new heads have the best possible mounting surface
Old 01-07-2013, 08:58 AM   #3
Ok , I'll check into that. I'm doing a pretty mild build , I am attempting it myself. It's kind of always something I've wanted to do and learn. Thanks for the input
Old 01-07-2013, 09:34 AM   #4
WhiteCobra94's Avatar
And if since your gonna put a cam in , you'll prob need to cam bearings
Old 01-07-2013, 09:46 AM   #5
I'm going to replace everything I can and just take my time with it. Should I hone the cylinder walls ? Or just leave them be if they look ok ?
Old 01-07-2013, 12:18 PM   #6
91notchback's Avatar
Just my opinion, but I say hone em! Anything to save headaches down the road.
---------- Post added at 02:18 PM ---------- Previous post was at 02:15 PM ----------
No need to send to a machine shop to do this. Buy a speed hone, slap it on the end of a drill, and put you some nice cross-hatching in it.
91notchback is offline   Reply With Quote
Old 01-07-2013, 12:31 PM   #7
I should add: you will need some type of bore gage to make sure you don't peel off too much metal if you plan on doin it yourself
Old 01-07-2013, 04:48 PM   #8
Cool thanks for the info , I will hopefully get started this weekend
Old 01-07-2013, 07:53 PM   #9
Finchms's Avatar
It should only take 3-5 strokes in the cylinder walls with the hone
It needs to be done so the new rings will seat properly. Honing is just for getting the glaze off the walls. Nothing complicated! Good luck!
Finchms is offline   Reply With Quote
Old 01-07-2013, 08:07 PM   #10
Thanks! I bought another 302 block cheap.. So I have a back up if I screw up too bad on the rebuild
Old 01-07-2013, 08:14 PM   #11
Finchms's Avatar
As long as there are no bad scars/gouges or things of that sort u should be good to go with the hone. Just 3-5 strokes is all. With that u should be fine: good
03:42 AM
