87-93 5.0 motor - Mustang Evolution
Old 01-10-2013, 08:22 PM   #1
Bpolley11's Avatar
87-93 5.0 motor
I am looking for a motor from a 5.0 mustang from 87-93. It could be just the motor or the whole car would work too if its for a good price, even if it is totalled.
Thanks
Bpolley11 is offline   Reply With Quote
Old 01-10-2013, 08:56 PM   #2
Look on craigslist in your area
keaton5.0 is offline   Reply With Quote
Old 01-10-2013, 09:02 PM   #3
Bpolley11's Avatar
I have some. I'm gonna start checking regularly. Thanks though!
Old 01-10-2013, 09:02 PM   #4
deadsp0t's Avatar
Mustang parts specialties in GA.. Well known and reputable. They also have an eBay store.
That's unimpressive
Old 01-11-2013, 09:06 AM   #5
WhiteCobra94's Avatar
Thanks
How much are you looking to spend? LMR has budget Shortblocks for $800
Old 01-11-2013, 09:15 AM   #6
deadsp0t's Avatar
I understand some of those are .040" which can be ok but aren't going quite as reliable in the 'long-term' as .020-.030 blocks. Be sure to ask.
That's unimpressive
Old 01-11-2013, 09:27 AM   #7
.030 is widely recommended as the maximum for a 302. Some people have run plenty of power in a .040 over block just fine tho, but like you said for how long?
Old 01-11-2013, 10:23 AM   #8
My block is bored .040 over so far to problems , runs like a champ!!!
Old 01-11-2013, 10:38 AM   #9
deadsp0t's Avatar
Meant no harm, actually I thought after I made the post I remembered yours was .040.
That's unimpressive
Old 01-11-2013, 10:40 AM   #10
Well so far so good, only time will tell !! !!
Old 01-11-2013, 11:42 AM   #11
I think the real problem with over bore motors is when you stroke it and get a poor rod ratio, more force on a thinner cylinder wall equals trouble over an extended period of time
Old 01-11-2013, 11:47 AM   #12
deadsp0t's Avatar
Yes, in most scenarios the thinner walls are the issue. Even with a stock stroke it 'can be an issue' causing cooling issues. It's not always an issue, a lot of ppl never have an issue. Like you said earlier its just the recommendation
That's unimpressive
Old 01-11-2013, 01:12 PM   #13
Bpolley11's Avatar
Probably somewhere around there. I talked to a guy at Dallas mustang and he said you can find alot of totaled cars and get them for $500-600 and just take the motor and scrap the rest.
Old 01-11-2013, 03:38 PM   #14
93slowstang's Avatar
If you're going to pick up a used motor look into the 5.0 explorers and mountaineers. Basically cobra motors with the exception of the cam.
Old 01-11-2013, 04:08 PM   #15
2300turboford's Avatar
+ 1 u need the closest stroke to rod ratio as possible
Old 01-11-2013, 05:09 PM   #16
Bpolley11's Avatar
What year explorer and mountaineer?
Old 01-11-2013, 05:12 PM   #17
96-01 explorer, 97-01 mountaineer.
Old 01-11-2013, 05:45 PM   #18
Bpolley11's Avatar
Ok. Thanks! I'll look into that too
Old 01-11-2013, 07:33 PM   #19
No problem
Old 01-12-2013, 07:24 PM   #20
Bpolley11's Avatar
How much trouble is it to put the newer overdrive transmission along with the new model roller motor in a 68 mustang.
Old 01-13-2013, 07:13 AM   #21
You are correct. And actually some blocks maybe fine even up to .060 over where others aren't. The best thing to do is a sonic test. Which can't be done when purchasing online. But anyways my point is not all blocks are created equal because of casting flaws. So just cause someone runs a high bore over doesn't mean someone else can. So with that said it is still risky.
04:15 PM
