Bucking issue. Please help - Mustang Evolution
Old 01-20-2013, 03:49 PM   #1
FRslimmyjim's Avatar
I have no idea what this issue is. The car has been sitting for 3 or so years andirons have brought it back to life. I have changed the spark plugs and wires. It goes great till I want to cruise and when I just barely push on the gas to remain at speed it starts to buck. Or jerk. It is very unpleasant and I need to figure this out. I am new to mustangs but not mechanics. And suggestion would help alot
FRslimmyjim is offline   Reply With Quote
Old 01-20-2013, 05:07 PM   #2
mustangmania91's Avatar
I can almost guarantee you that it is your TFI module on your distributor. About a $40 or less fix and easy to do. Go to local aftermarket parts store. Simple fix. Had this issue on my 91GT and had no clue. Changed the module and problem solved
mustangmania91 is offline   Reply With Quote
Old 01-20-2013, 06:38 PM   #3
Finchms's Avatar
+1 on the tfi module but also could be distributor cap. If it has a hairline crack anywhere it could also cause the bucking. I would check that first as its alot cheaper than tfi module.
Finchms is offline   Reply With Quote
Old 01-20-2013, 07:02 PM   #4
2300turboford's Avatar
What cam does it have in it and is it a 5 speed ?
Old 01-20-2013, 07:10 PM   #5
+1 finchms. Very well cld be distributor cap and or rotor. I had no clue and changed the TFI module. Had no issues after that. Anyways, good luck and be sure to post what u find. Thanks!
Old 01-21-2013, 08:59 AM   #6
93slowstang's Avatar
If its only doing it under light acceleration or cruising I would suspect your fuel filter being the main problem. You'd be surprised what havoc 3 years of sitting can do to a fuel system.
Old 01-21-2013, 09:16 AM   #7
+1 93 slow stang
Old 01-21-2013, 11:03 AM   #8
v8pony's Avatar
Originally Posted by mustangmania91 View Post
+1 93 slow stang
+10473
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-21-2013, 12:29 PM   #9
I changed the fuel filter already that was one o the first things I did. I changed the tfi and still no luck
Old 01-21-2013, 04:38 PM   #10
Wow. I wld have swore that the tfi moduke was the culprit. I apologize. Only other thing i cld think of that u havent already done wld be the distributor rotor and cap. How old are the plugs and wires??? Possibility of that as well
Old 01-21-2013, 05:57 PM   #11
I changed the spark plugs and wires already as well
Old 01-21-2013, 06:00 PM   #12
Finchms's Avatar
U checked the cap for cracks or anything?
Old 01-21-2013, 06:03 PM   #13
If u have a big cam an a manual transmission it will buck at slow speeds and under light acceleration
Old 01-23-2013, 01:21 PM   #14
I don't know if it has a big cam in it or not. The idle is loopy for sure. Also the car has a scratch on it but that's it. Would that affect anything?
Old 01-23-2013, 01:29 PM   #15
Finchms's Avatar
If the gears aren't matched with a bigger cam it will cause the bucking. This can happen from just trying to take off easy and if u runnin low rpms in a high gear while trying to accelerate.
Old 01-23-2013, 05:14 PM   #16
Is there anyway I can figure outbid I have a bigger cam?
---------- Post added at 07:14 PM ---------- Previous post was at 07:12 PM ----------
Is there any way I can figure out if I have bigger cams or not?
Old 01-23-2013, 05:19 PM   #17
Uhh taken's Avatar
Just punch the throttle everywhere? Should stop the bucking.
Uhh taken is offline   Reply With Quote
Old 01-25-2013, 09:28 AM   #18
I don't want to punch it everywhere. I like to cruise. I have another car that I specifically built to punch it. Should I just do the distributor and cap nod If that doesn't work just leave it?
Old 01-25-2013, 04:44 PM   #19
Billymich's Avatar
I laughed so hard
Old 01-25-2013, 07:10 PM   #20
Finchms's Avatar
I would try the cap n rotor as its fairly cheap n check your fuel pressure also.
Old 01-26-2013, 05:45 PM   #21
Okay. I'll try that. Thanks
« Oil Leak | Belt »
08:44 AM
