Belt Tensioner - Mustang Evolution
Old 01-22-2013, 09:24 AM   #1
Ewokjax95's Avatar
Belt Tensioner
Has anyone had any problems with the stock tensioner on the 1994-95 cars? Mine seems to be tightened down but it moves at idle. Not the pulley, but the whole mechanism. Bad spring in the tensioner maybe? It makes a clanking sound at idle as well. Thanks
Ewokjax95 is offline   Reply With Quote
Old 01-22-2013, 09:31 AM   #2
It should move some when the motor is running, however the spring can weaken over time and the assembly will need to be replaced.
Old 01-22-2013, 09:51 AM   #3
deadsp0t's Avatar
^yup!
Op how many miles?
That's unimpressive
Old 01-22-2013, 11:33 AM   #4
Ewokjax95's Avatar
The odometer stopped at 173k in 2006 lol I suppose it is probably in need of replacement. The idler pulley tends to make noise so I may replace that one as well.
Old 01-22-2013, 11:39 AM   #5
deadsp0t's Avatar
it may just be a worn belt. If you are going to replace those other parts, slap a new belt on there as well.
That's unimpressive
Old 01-22-2013, 01:39 PM   #6
Ewokjax95's Avatar
Just got a new belt 4 days ago because of UDPs and the belt before that was only 3 months old because I deleted the smog pump. I'll replace the tensioner and see if that fixes it.
Old 01-23-2013, 09:32 PM   #7
deadsp0t's Avatar
Was it doing it before the UDP and new belt?
That's unimpressive
Old 01-24-2013, 09:04 AM   #8
Ewokjax95's Avatar
Nope. Is there a possibility that the UDP caused the tensioner to start failing?
Old 01-24-2013, 09:38 AM   #9
deadsp0t's Avatar
Are you positive you have the right length belt?
That's unimpressive
Old 01-24-2013, 02:15 PM   #10
Ewokjax95's Avatar
I'm pretty sure I do. It fits fairly tight on the front accessories. I used the routing in this link. The length of the belt I got is 89.5" tho. http://www.allfordmustangs.com/forum...lt_routing.jpg
Old 01-24-2013, 02:19 PM   #11
deadsp0t's Avatar
Using middle right?
That's unimpressive
Old 01-24-2013, 04:44 PM   #12
Ewokjax95's Avatar
Middle left. Smog pump is only thing eliminated.
Old 01-24-2013, 06:24 PM   #13
deadsp0t's Avatar
That's odd.. Maybe it's too tight.. There should be a guide in a Haynes or Chiltons how to manually check the tension with a straight edge between two pulleys and measuring how far you can move the belt.. Free test before throwing parts at it.
That's unimpressive
Old 01-25-2013, 10:03 AM   #14
Ewokjax95's Avatar
I'll check that tonight I suppose. I really don't mind throwing parts at it but if I don't have to, I won't.
07:23 AM
