Need some suspension idieas - Mustang Evolution
Old 01-23-2013, 07:38 AM   #1
2300turboford's Avatar
I have a 85 gt with a built 2.3 turbo in it it has been lowered and has Pollyurthane bushings I need some more ideas ps this is gonna be a corner carver
Old 01-23-2013, 07:57 AM   #2
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
If your current shocks and struts are good, I would upgrade to a more aggressive brake pad like Hawk HPS, subframe connectors, and add some front camber with some bolts or plates.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 01-23-2013, 08:06 AM   #3
I have some gripp subframe connectors an brand new brake pads
Old 01-23-2013, 08:35 AM   #4
Nice, I would then look into camber bolts or plates to aid in turn in. Possibly sway bars and control arms next? I know it's not cheap, but some wider rims and tires would help tremendously.
Old 01-25-2013, 05:19 PM   #5
Billymich's Avatar
First: Full length sub frame connectors ((welded) Professionally ), 3 point strut brace, 2 point welded shock brace (skip rear brace if a roll cage is in order =D ), PolyUrethane Bushings for All! Convertible or solid Motor mounts
Second: Larger lighter control arms front and rear (skip rear if you're going Panhardbar/Torque arm), Larger sway bars. Lowering springs(progressive rate)/Adjustable Shock/Struts, Bumpsteer kit.
Third: Full coilovers, 17x8in front 17x9in rear tires, Roll Cage, Torque Box reinforcement, weight reduction, 4 point k-member brace or Tubular K-member.
im sure i missed stuff was distracted
Old 01-25-2013, 05:43 PM   #6
deadsp0t's Avatar
Get 4-bolt CC plates.. Maximum Motorsports..
Do it right, don't half-*** it bro
That's unimpressive
04:01 AM
