Oil Leak - Mustang Evolution
Old 01-24-2013, 01:03 PM   #1
Oil Leak
So I noticed I have a scrape on the front end of my oil pan. This happened to me before so I replaced the oil pan and the front struts but it seems that its hitting the sway bar. Am I missing something here? And no I don't drive erratically but the city streets are bumpy but not a lot
---------- Post added at 01:03 PM ---------- Previous post was at 01:02 PM ----------
Posted a pic. Not sure if you guys can see it
Jolvera_92 is offline   Reply With Quote
Old 01-24-2013, 01:10 PM   #2
deadsp0t's Avatar
I can't see it..
That's unimpressive
Old 01-24-2013, 01:20 PM   #3
Old 01-24-2013, 01:20 PM   #4
There you go.
Old 01-24-2013, 01:21 PM   #5
Finchms's Avatar
U sure the bolt is tight? From the pic it looks like the oil is coming from there.
Finchms is offline   Reply With Quote
Old 01-24-2013, 01:24 PM   #6
deadsp0t's Avatar
Agreed...
That's unimpressive
Old 01-24-2013, 01:30 PM   #7
Yea its tight. I can see why you guys think that but idk if you guys can see the scrape right underneath and on the bolt itself
Old 01-24-2013, 01:41 PM   #8
Rickv09GT500's Avatar
It looks like the plug bolt isnt seating right. That may mean the hole was deformed. Check the plastic gasket on the bolt after draining the oil to see if it is damaged. If it looks ok and still leaks you will probably have to replace the pan to stop it.
2009 Shelby GT500
#1289 of a build of 3004 coupes.
#51 of 156 coupes manufactured in Alloy Metallic.
Pype Bombs exhaust and Nitto 555 tires
Rickv09GT500 is offline   Reply With Quote
Old 01-24-2013, 03:44 PM   #9
Finchms's Avatar
Or clean up the pan some n use some jb weld if u have a crack or anything. Summin to get u by till u get another pan or have that one fixed the right way.
Old 01-24-2013, 03:58 PM   #10
Thanks guys but I'm trying to figure out why the oil pan is hitting the sway bar
Old 01-24-2013, 04:06 PM   #11
Finchms's Avatar
It shouldn't be unless the sway bar is bent or maybe the motor mounts are shot n the rubber is gone out of em causing the motor to sit lower.
Old 01-25-2013, 04:58 PM   #12
Billymich's Avatar
My mounts went bad causing my engine to do the same thing its easy to check too.
Old 01-25-2013, 06:26 PM   #13
91notchback's Avatar
And fairly easy to change them. It sounds intimidating with lifting the motor by the oil pan and all, but, all in all not too bad!
91notchback is offline   Reply With Quote
Old 01-25-2013, 07:59 PM   #14
DerekJohnScott's Avatar
Mine leaks oil from the bolt/ plug. It could be that.
DerekJohnScott is offline   Reply With Quote
Old 01-26-2013, 10:21 AM   #15
To check the motor mounts put it in drive, hold the brake down, then give it some gas. Then do the same procedure in reverse. This will check both motor mounts. If the motor torques a lot then u need new ones.
09:03 PM
