Belt - Mustang Evolution
Old 01-27-2013, 09:20 AM   #1
Jmanlev's Avatar
Belt
I took off my old serpentine belt because my a/c compressor went out and I didn't want my belt to break so I bought the same belt for my model only w/out a/c and it doesn't even fit. What could be the problem? Am I better off buying a ford racing a/c pulley replacement?? PLS HELP, thanks!!
Jmanlev is offline   Reply With Quote
Old 01-27-2013, 11:28 AM   #2
Cobrarunnin9s's Avatar
Just run a string around all the pullies you need to run and measure it. While your at it bypass the smog pump to.
Cobrarunnin9s is offline   Reply With Quote
Old 01-27-2013, 11:37 AM   #3
Rosco's Avatar
If you want to run the oem length belt get a ac/delete pulley. Or do as stated with the string and bypass that and the smog pump.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 01-27-2013, 11:58 AM   #4
You can reroute the factory belt to work without ac...
Old 01-27-2013, 03:58 PM   #5
87mustangGT's Avatar
Amrican racing has a kit the gives you brackets the moves your powersteering pump to where the ac used to be its like $55 i did it in my 90 you can use the non ac belt then
87mustangGT is offline   Reply With Quote
04:03 AM
