Strut tower - Mustang Evolution
Old 01-27-2013, 08:31 PM   #1
Cblackstang's Avatar
Strut tower
I just got a 95 GT and the strut towers are rusted out..any ideas to fix it?
Cblackstang is offline   Reply With Quote
Old 01-27-2013, 08:57 PM   #2
1slosix's Avatar
Sand it then paint with engine enamel
carving corners like a boss
Old 01-28-2013, 09:44 AM   #3
It's beyond sanding..there is about a 1" gap half way around
Old 01-28-2013, 09:57 AM   #4
1slosix's Avatar
Hmm did you say you had a v6 roller
Old 01-28-2013, 05:34 PM   #5
It's not exactly a roller..it still has motor and trans, still drivable
Old 01-28-2013, 06:16 PM   #6
WhiteCobra94's Avatar
New one is $125
Old 01-28-2013, 06:27 PM   #7
Where?
Old 01-28-2013, 06:33 PM   #8
Originally Posted by Cblackstang View Post
Where?
http://m.summitracing.com/parts/bbk-2513
Old 01-28-2013, 07:23 PM   #9
Billymich's Avatar
No his actual strut towers are rusted, on the chasis... I think?
Old 01-28-2013, 07:33 PM   #10
Where?
Take a picture and post it when you can
Old 01-29-2013, 06:43 AM   #11
04machazblue's Avatar
My shock Tower was rusted out not the Frame rail I cut out all the rust and welded a piece of metal there grind smooth then painted can see it but its much better
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 01-29-2013, 07:53 AM   #12
Yea the strut tower on the body..that's what I'm thinking about doing is welding a piece of Steel In and use my V6 as a donor
Old 01-29-2013, 08:01 AM   #13
It's not that bad it was easy bc the motor was out of it though
---------- Post added at 11:01 AM ---------- Previous post was at 11:00 AM ----------
U can use any steal really I used 14 gauge steal
02:09 PM
