AFR heads - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Old 01-29-2013, 09:26 AM   #1
Ewokjax95's Avatar
Ewokjax95 is unknown around these parts
AFR heads
Well I've made up my mind that AFR has the proven gains I want but I still have questions for you engine building guys. I am aware that the 165cc heads will probably clear the valves on a stock cam but what about the 185s? I ask this because I honestly don't want to have to check clearance with clay then have to clean pistons. I just want to bolt on and go. I believe AFR recommends not using a cam with over .500 lift? Also on stock bottom end and stock cam, what would the 185ccs with 58cc combustion chambers raise the compression to approximately? I'd like to be upwards of 10.5:1. Anyone and everyone weigh in on this if you'd like to. Thanks
Don't you just love it when your car goes KAPOOYAH between shifts.
Ewokjax95 is offline   Reply With Quote
Old 01-29-2013, 09:59 AM   #2
2300turboford's Avatar
2300turboford is unknown around these parts
My freind has the 165 cc on his fox with a small cam and there was a huge difference over the trick flows he used to have
Old 01-29-2013, 10:17 AM   #3
Ewokjax95's Avatar
So your saying the difference was better as in the AFRs were better?
Old 01-29-2013, 10:29 AM   #4
Yes I am a full believer in afr heads u won't be sorry well worth the money !!
Old 01-29-2013, 10:38 AM   #5
Ewokjax95's Avatar
Yep. That's what I've been told but I'm just trying to be cautious. I'd hate to pay 1500$ for them and find out I need fly-cut pistons. It is my dd after all. I suppose I should do a little more research.
Old 01-29-2013, 11:13 AM   #6
keaton5.0 is unknown around these parts
From my research the trickflow 170s flow like the afr 180, just with a shorter runner due to the twisted wedge design. It also makes the trickflows much friendlier with larger cams on stock pistons
keaton5.0 is offline   Reply With Quote
Old 01-29-2013, 11:34 AM   #7
Senior Member
dreamstang is unknown around these parts
Trickflow/afr is one of those never ending debates. You can read a million threads about which ones are better. They are both great heads and you will be happy with either.
But to answer the op question. 185s has less valve clearance then the 165s. I believe the product information says "requires special pistons". But for a mild 302 build 165s are a great head. You wouldn't see much gain with a small cam and stock stroke going with the 185s over the 165s.
Old 01-29-2013, 11:35 AM   #8
Senior Member
Yup, that's what I came up with to. .
Old 01-29-2013, 04:28 PM   #9
It claims 95 hp gain over gt40x heads
Old 01-29-2013, 06:42 PM   #10
JayKranz is unknown around these parts
Also, the compression ratio should not change considering your stock heads are also 58cc.
JayKranz is offline   Reply With Quote
Old 02-01-2013, 06:03 AM   #11
WhiteCobra94's Avatar
WhiteCobra94 is unknown around these parts
Go Edelbrock RPM Heads lol!!
Old 02-01-2013, 06:37 AM   #12
04machazblue's Avatar
04machazblue is unknown around these parts
I think if you match the cam up better with a set of trick flow heads I have a lot of friends with 170 track heats going 11.6 with stock bottom end and 5 speed, which head you want is a personal preference flow numbers aren't everything it's about the velocity the that makes the power also. But trick flow and afr are both great company's can't go wrong
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 02-02-2013, 09:44 AM   #13
captain78's Avatar
captain78 is unknown around these parts
Well i have the afr 165s with a custom cam with a 590 lift no Clearence issue with stock bottom end i love my afr heads
captain78 is offline   Reply With Quote
Old 02-02-2013, 01:03 PM   #14
Duration is what causes piston to valve clearance
Old 02-02-2013, 04:15 PM   #15
The420fox's Avatar
The420fox is unknown around these parts
What's the Highest duration Afrs can run then? Do you know?
The420fox is offline   Reply With Quote
Old 02-02-2013, 05:42 PM   #16
Senior Member
There no set amount. Every motor is different and there is way to many variables. Even if you were to call afr themselves they would tell you to check piston to valve clearance.
The area most likely to have clearance can be any where from -20* to +20* from tdc.
Old 02-02-2013, 05:44 PM   #17
The420fox's Avatar
Thanks dreamstang
Old 02-02-2013, 05:44 PM   #18
Senior Member
Thanks dreamstang
Your welcome. And I added a bit to my last post.
12:19 AM
