HELP, Idle issues! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Old 01-31-2013, 06:47 PM   #1
Vazqueza90's Avatar
Vazqueza90 is unknown around these parts
HELP, Idle issues!
So when I start my car in the morning it idles to 1000 the drops to 700 then dies..
What's can be wrong with it.?
Or where should I begin the process of elimination.?
Vazqueza90 is offline   Reply With Quote
Old 01-31-2013, 07:06 PM   #2
1slosix's Avatar
1slosix is just getting started.
clean your IAC
carving corners like a boss
Eibach Strut Tower Brace - Rear Shock Tower Brace - GT Rear Sway - Goodridge Gstop SS lines - SR Performance Springs - Sensa-trac Shocks - Mac Prochamber - Borla Stinger 2.5" Mandrel Catback - K&N - Torqthrust Wheels wrapped in Kumo's - TB Spacer - HIDs & Other Visual Goodies
Old 01-31-2013, 08:32 PM   #3
Vazqueza90's Avatar
Originally Posted by 1slosix View Post
clean your IAC
I just bought a new one a month ago because cleaned the old one and same problem
Old 01-31-2013, 10:10 PM   #4
Vazqueza90's Avatar
Bump
Old 01-31-2013, 10:14 PM   #5
Venomouz831's Avatar
Venomouz831 is unknown around these parts
Check for leaks
)02 Gt, Founder of WE2G
Old 01-31-2013, 10:20 PM   #6
Vazqueza90's Avatar
Originally Posted by Venomouz831 View Post
Check for leaks
Any where specific.?
Old 01-31-2013, 11:49 PM   #7
Slp_loudmouth's Avatar
Slp_loudmouth is unknown around these parts
Mass air flow ? Throttle position? They could be it try cleaning the mass air flow first. Could also be a vacuum line
Slp_loudmouth is offline   Reply With Quote
Old 02-01-2013, 05:58 AM   #8
WhiteCobra94's Avatar
WhiteCobra94 is unknown around these parts
*1 , the only thing I can think would do that are the Dirty MAF, TPS or IAC
Old 02-01-2013, 07:40 AM   #9
Vacuum line can as well
Old 02-01-2013, 02:00 PM   #10
Vazqueza90's Avatar
What vacuum line.?
It only does it in the morning..
I'm going to buy a new tfi today
Ill post up a video when I get home
Old 02-01-2013, 02:06 PM   #11
What vacuum line.?
Oh if it's only in the morning it's one of the sensor most likely going bad
Old 02-01-2013, 08:20 PM   #12
Vazqueza90's Avatar
Here's the videos
http://youtu.be/Z2WMYXQolv8
http://youtu.be/0rjfI8l62mo
Old 02-01-2013, 09:07 PM   #13
Vazqueza90's Avatar
Bump
Old 02-01-2013, 10:58 PM   #14
Mass air flow
Old 02-02-2013, 09:45 PM   #15
94GT302's Avatar
94GT302 is unknown around these parts
Had this problem and my MAF was bad. Then changed all the vacuum lines including the one under the intake(hard to get to without removing the upper intake) but now she runs like a breeze. Need to change my TPS though I think it's going out. Good luck
94GT302 is offline   Reply With Quote
Old 02-02-2013, 11:09 PM   #16
91notchback's Avatar
91notchback is unknown around these parts
You can drill/mill out the slots on ur TPS to set it to the correct .98-.99 also!
91notchback is offline   Reply With Quote
Old 02-04-2013, 05:38 PM   #17
94GT302's Avatar
Did this thanks a lot man!! Saved me some $$$$
Old 02-04-2013, 06:37 PM   #18
Anytime man.
Old 02-04-2013, 07:52 PM   #19
06gt2fast4u is unknown around these parts
I had same problem with my 88 gt conv... i changed out map sensor and problem was solved
06gt2fast4u is offline   Reply With Quote
Old 02-04-2013, 07:55 PM   #20
Ubnbit's Avatar
Ubnbit is unknown around these parts
This is where to start.
Tint, American Muscle louvers, Shelby 3rd Brake light cover, sequential tail lights, brake vent ring delete. Shorty antenna. JLT cold air intake, BAMA tune. VMP 2.5 S/C pulley. Ford racing shifter, SLP loudmouths.
Old 02-04-2013, 08:09 PM   #21
Vazqueza90's Avatar
I'm new to this where r the vacuum lines again.?
I'm cleaning the maf this weekend
Old 02-06-2013, 08:54 AM   #22
Vazqueza90's Avatar
Any idea y my car starts up all slow
Bad connection,starter
Old 02-06-2013, 09:08 AM   #23
Define "starts up all slow"
Old 02-06-2013, 09:33 AM   #24
Vazqueza90's Avatar
The video on pg 1 it shows what I mean
Old 02-06-2013, 09:46 AM   #25
You try replacing map sensor?
Old 02-06-2013, 10:13 AM   #26
Vazqueza90's Avatar
I'm doing it this weekend
Can it be that.?
Old 02-06-2013, 04:29 PM   #27
Yeah my 88 gt did the same thing... im not saying its def that... but my car did same thing i changed map sensor and blamo..... problem solved.
Old 02-06-2013, 10:17 PM   #28
Krazy Horse's Avatar
Krazy Horse is unknown around these parts
If map sensor don't fix it you check the EGR valve. It made my 2 88 mustangs cold natured when I had them disconnected to race. Did same thing u described, crank run up n down idle then die. Had to rev till warm then was fine. I replaced my EGR n reconnect vacuum lines and all better
Krazy Horse is offline   Reply With Quote
2v to 4v finished... driveablility issues... Smokum281 1996-2004 Mustang GT 13 12-18-2012 07:54 AM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 25 11-19-2012 09:54 PM
AOD to T5 Swap & Idle, Bucking Issues Trojan Horse 1979-1995 Mustang GT 5 02-06-2012 09:47 AM
Interior Issues? Dion11197 2010-2014 Mustang GT 20 12-05-2011 06:55 AM
Idle issues HELP DHall31 General Mustang Discussion 9 11-23-2011 05:33 PM
08:45 PM
