Carb guys - Mustang Evolution
Old 02-01-2013, 07:39 AM   #1
04machazblue's Avatar
Carb guys
I was running my motor and I got a flame for a split second come out of the carb. The car runs pig rich I know the jet is maxed out how I got the carb changing the jets very soon but I was just wondering could running rich cause the carb to do that I am new to the carb thing
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 02-01-2013, 08:07 AM   #2
deadsp0t's Avatar
Timing
That's unimpressive
Old 02-01-2013, 08:37 AM   #3
Timing is dead on I have gas in it regular but it's from September and I have the timing set to trickflow specs
Old 02-01-2013, 09:52 AM   #4
Region: Hawaii
Running really rich will do that I've had it happen a couple of times as well could have also been a misfire so check your plugs and make sure their all good also if your running rich you would need to dial back the timing a little bit not much but some timing needs to be set for how rich the fuel is its really up to you at this point I would check the plugs first and make sure their good first if they are then you could either adjust the timing a tiny bit or lean It out a little either one should fix your issue
67Stangman is offline   Reply With Quote
Old 02-01-2013, 11:08 AM   #5
If the jet is maxed out you maynot be able to fix it until you change them. But what is your fuel pressure set at? I would set it at 6 psi and the timing at about 12 until you get smaller jets.
Old 02-01-2013, 03:30 PM   #6
I figured it out a couple plug were failed took them out wire brushed them and bam running good but jets are coming down tonight
Old 02-02-2013, 07:57 AM   #7
We went down two sizes on the front of the carb and blocked the power valve off run a nice and crisp
12:36 PM
