New engine - Mustang Evolution
Old 02-01-2013, 09:14 AM   #1
Fiveohfox's Avatar
New engine
Ok my 302 was put in, never got tuned or idle set or anything. What do I NEED too do? I don't want it on a dyno getting redlined when I'm not even done with it yet so do I just take it somewhere and get the air/fuel, timing, and idle?
Much apprecieated guys
Fiveohfox is offline   Reply With Quote
Old 02-01-2013, 03:12 PM   #2
What is done to it? If its just a mild build then it doesn't need to be on a dyno. Just set your timing and fuel pressure if you have an adjustable regulator. Then do an idle relearn.
Old 02-01-2013, 05:48 PM   #3
Fiveohfox's Avatar
Mild build just cam, heads, valve covers, 24lb injectors 75mm throttle body. I did timing today and it idles a little better, and what's idle relearn?
Old 02-01-2013, 05:59 PM   #4
here is the procedure:
Disconnect the battery's negative terminal to reset/clear the computer's memory. Leave it disconnected for 30 minutes.
Disconnect the plug going to your idle motor which is located on the front of your throttle body.
Reconnect your battery's negative terminal.
Start the engine, and set the idle to the rpm you want with the stop screw on the bottom of the throttle body. (arrow)
Turn off the engine.
Reconnect the plug on the idle motor.
Make sure all accessories (radio, blower motor, a/c, lights, etc) are off and start the engine.
Let engine run for two minutes.
Turn engine off and wait two minutes then restart engine and let idle for two minutes with all accessories on.
If everything was done properly the EEC-IV (read: computer) should have learned it's new idle.
Old 02-01-2013, 08:58 PM   #5
Fiveohfox's Avatar
Wow thanks! I'm doing that tomorrow then, is the iac right where the intake meets the intake manifold? Cause someone was looking at mine and they said mine is missing
Old 02-02-2013, 04:16 AM   #6
Yeah I don't remember exactly cause I don't have one.
Old 02-15-2013, 06:12 PM   #7
Fiveohfox's Avatar
Had my car tuned today
Starting out 207hp 256tq
After tune 240hp 276tq
No more backfires runs so clean and smooth
Old 02-15-2013, 06:24 PM   #8
Cool man. Good numbers.
Old 02-15-2013, 06:24 PM   #9
Fiveohfox's Avatar
Thanks
Old 02-15-2013, 06:26 PM   #10
Fiveohfox's Avatar
Old 02-15-2013, 07:08 PM   #11
What heads are u running
Old 02-15-2013, 07:10 PM   #12
Fiveohfox's Avatar
Patriot heads
10:19 PM
