Need help with gt40 and cam choice - Mustang Evolution
Old 02-01-2013, 11:02 PM   #1
WhiteKnightGT's Avatar
Alright so as we all know... It's tax time.
My uncle and rest of the family are due hard Chevy guys. I wanted to be a black sheep that could put em in their place.. So I got a 87 gt 5 speed to play with.
I am looking for any information on gt40 and gt40p heads as well as intakes for my 5.0 and cam options. I want a hell of a good street car that will run like a scolded dog.
If you can help please call me anytime I'm up all hours5672047113 I'm in Ohio as well if ya know of any parts or happen to have a set I can buy!
---------- Post added at 01:02 AM ---------- Previous post was at 01:01 AM ----------
I am curious if there's a good cam kit I can use with those heads and intake as well as what all will be needed. A list would be exceptional!
WhiteKnightGT is offline   Reply With Quote
Old 02-01-2013, 11:06 PM   #2
deadsp0t's Avatar
If you haven't already you'll need to swap over to Mass air before getting that deep with a Heads/Cam/Intake swap
That's unimpressive
Old 02-01-2013, 11:07 PM   #3
That's why in askin what all ill need haha.. Trying to figure this all out
Old 02-02-2013, 01:21 AM   #4
Billymich's Avatar
go to Home thats where i got my mass air stuff.
http://shop.fiveologyracing.com/MUST...ERSION_c13.htm
Old 02-02-2013, 02:45 AM   #5
91notchback's Avatar
TFS stage 1 is a good cam to use with these heads. I would change valve springs, roller lifters, and pushrods while you're at it. Either set of heads is a good choice. Header clearance will be a little tight with the P heads.
91notchback is offline   Reply With Quote
Old 02-02-2013, 02:51 AM   #6
Also, a MAF from a 94-95 mustang (70mm stock) and a TB from an explorer (65mm stock) can be used with minimal alterations. Explorer, gt40 tubular, or 93 cobra intake.
Old 02-02-2013, 10:04 AM   #7
I have bbk headers and a bbk 70mm throttle body and was just curious if I snag those heads and that intake if I can use them
Old 02-02-2013, 10:14 AM   #8
You can use them with either set of heads. Like I say, headers will be a tight fit with the P heads.
Old 02-02-2013, 05:34 PM   #9
93slowstang's Avatar
+1
Old 02-02-2013, 06:50 PM   #10
Originally Posted by 93slowstang View Post
+1
By the way: header info provided by 93slowstang in a previous thread. Can't take all the glory!!
Old 02-02-2013, 08:57 PM   #11
Thanks, there's also a write up in the stickies under useful info about it too.
And here's pics of my BBK shorties with the "P" heads.
ID:	88909   Click image for larger version
Old 02-05-2013, 02:51 AM   #12
B303 cam has nice sound without having to make any modification.
06gt2fast4u is offline   Reply With Quote
Old 02-05-2013, 08:09 AM   #13
Has nice sound, but won't make the power your lookin for with those heads.
---------- Post added at 10:09 AM ---------- Previous post was at 10:07 AM ----------
Remember: Power is made by the combination of parts working TOGETHER.
Old 02-05-2013, 11:07 AM   #14
Think ill go with the maf conversion with gt40ps and a gt40 intake upper and lower with e303
Old 02-05-2013, 12:48 PM   #15
Good choice my friend!!
Old 02-06-2013, 12:28 AM   #16
Not a bad choice, that's the combo I'm running at the moment.
Old 02-06-2013, 01:11 AM   #17
Gotta change springs for e303?
Old 02-06-2013, 02:58 AM   #18
If they are low mileage heads you don't have to but it doesn't hurt to put some fresh springs in. They can handle the lift but you may have valve floating issues in the higher RPMs with the stockers.
Old 02-06-2013, 03:21 AM   #19
I thought there was a hang up... im thinking of getting a block and building a 5.0 motor this summer... with the 40p heads bbk shorty's are only ones that work due to plug angle right?
Old 02-06-2013, 03:43 AM   #20
MAC and FRPP both make "P" specific headers if you don't already have headers, they make it a lot easier to use the "p" heads. I know other headers can work with them like the BBKs but they are justas bad with plug clearance.
Old 02-09-2013, 09:46 AM   #21
Got my gt 40 intake and lifter set yesterday. Gotta go pick up my f303 cam I decided to go with and I am picking up a set of afr heads from a bud to drop on. I just did plugs and wires last night and spent about 3 hours cleaning car
Old 02-09-2013, 10:26 AM   #22
Are the afr heads 165s or 185s? I have read numerous stories about low piston to valve clearancing with those heads. I have also seen people get away with decent size cams. Let us know how much ptv clearance you have when you install those. Even a small write up would be much appreciated.
Old 02-09-2013, 02:01 PM   #23
The420fox's Avatar
+1 I would be very interested in this,it would be appreciated if you could
The420fox is offline   Reply With Quote
02:12 PM
