Smog bypass - Mustang Evolution
Old 02-02-2013, 01:58 PM   #1
Fiveohfox's Avatar
Smog bypass
Snybody know the belt size to just bypass my smog pump? The delete pulley broke so I'm just going to bypass it. Thanks!
Fiveohfox is offline   Reply With Quote
Old 02-02-2013, 02:00 PM   #2
You can use the same belt, just reroute it.
Old 02-02-2013, 02:09 PM   #3
WhiteCobra94's Avatar
IMO I would get the smog delete pulley for $80
Old 02-02-2013, 05:20 PM   #4
Fiveohfox's Avatar
No I have the bypass pulley but one of the bolts broke and instead of taking out the altenator so I could drill the other half of the bolt out I just took it off and got a shorter belt. Why do you recommend keeping the delete pulley?
Old 02-02-2013, 05:46 PM   #5
Take the belt you have now.
Cut it to proper length.
Duct tape it together.
Then go to the auto parts store and match it up.
Old 02-02-2013, 05:52 PM   #6
deadsp0t's Avatar
That's unimpressive
Old 02-02-2013, 06:54 PM   #7
Fiveohfox's Avatar
Thanks guys I have it set up. Now is this better than putting my smog delete pulley on?
Old 02-05-2013, 02:58 AM   #8
I would say take the smog crap off and run a shorter belt... i did this on my 88 gt conv. It causes less drag than using the delete pulley.. i deleted ac and smog on mine and installed steeda under drives and there was a noticeable gain. But i had hooker shorty equal lengths bbk o/r h and 40 series flowmasters. Tranny was an aod with 4r70w internals and a 3000 stahl converter. Also had profesional products 70mm throttle body and 3 inch spacer with professional products intake... she was very mean. But the smog and ac delete made a good difference with the underdrives.
06gt2fast4u is offline   Reply With Quote
Old 02-08-2013, 08:53 AM   #9
just remove the smog pump. and the entire smog system. lightens the car up a bit. and you dont have to spend much money on it. if your mechanically capable. its not that difficult to do yourself. just be cautious of the smog regulations where you live. living in dubai. i wont have a problem. anywhere else in the world i cant comment on. good luck!
scott_anderson is offline   Reply With Quote
Old 02-08-2013, 09:08 AM   #10
Fiveohfox's Avatar
Yeah I took the smog pump off Is that the only smog part on the car other than the cats?
Old 02-08-2013, 09:23 AM   #11
That and the EGR. It connects your intake manifold to your headers. a simple delete plate on the manifold and a plug on the headers will suffice just make sure its all tight. You dont want an exhaust leak or an intake leak after the MAF for obvious reasons.
---------- Post added at 08:23 PM ---------- Previous post was at 08:21 PM ----------
This is of course assuming you have stock headers and intake manifold.
Old 02-08-2013, 09:24 AM   #12
Fiveohfox's Avatar
Ok I'm just wondering cause I'm kind if considering putting the pump back on when I do my swap just didnt know what else it would require
---------- Post added at 08:24 AM ---------- Previous post was at 08:23 AM ----------
Aftermarket
Old 02-08-2013, 09:30 AM   #13
to remove the pump altogether. all you need is a shorter belt (cant tell you the size as i cant remember) Its beneficial power and weight wise to just remove the system.
Old 02-08-2013, 10:01 AM   #14
Agreed delete it altogether.... unless your car has less than 2k miles and is pristine you have no use for it unless your in an emission check state
06:16 PM
