95 GT Auto Tranny Limits? - Mustang Evolution
Old 07-13-2008, 09:25 PM   #1
Thomas91169's Avatar
Whats the approximate power limit the 95 Auto (AODE?) can hold?
Also, what are options, cost and vendors for modded AODE's?
New local wants to know if he can slap on a Procharger/Vortech kit and be good to go or if that tranny is gonna laugh in his face.
-Thomas-
Old 07-31-2008, 07:59 AM   #2
Re: 95 GT Auto Tranny Limits?
I've seen stock AODEs running 400rwhp on drag radials and living, but it is a crap shoot. The stock converter is usually not happy with that kind of power. Another issue to consider is that the stock transmission/tune usually cannot shift fast enough on a high powered car (the revs build too quickly for the stock shift points to shift before you hit the limiter). This can all be fixed in the tune but it is another item to consider.
Lastly, going WOT into 4th gear will kill the band relatively quickly, it just cannot hold the power. I like to setup my automatic tunes to keep the car OUT of 4th at WOT in case the driver forgets to disable overdrive.
Most (myself included) move to a v6 4R70W transmission which is an AODE with stronger parts and a wider ratio in the lower gears, an upgraded converter stalling around the start of the cars powerband and a shift kit (Jmod). This transmission has to have a couple things taken over from the '95 transmission (tailshaft, solenoids) but it is a straightforward procedure.
If you need more detailed information let me know and I'll be happy to help.
Wes
Total Performance Solutions Dynotuner
['95 GT 11.66@119] ['07 GT 12.98@107] ['72 Mach 1]
stanger007 is offline   Reply With Quote
Old 07-31-2008, 09:51 AM   #3
I think on them as you start to push 300rwhp you are on borrowed time if they are 100% stock
2001 Auto Tranny Hesitant Shifting OsirisGuy Pre-2005 V6 Mustang 17 11-14-2008 06:35 AM
2000 V6 Auto Tranny Help petrey10 Pre-2005 V6 Mustang 1 07-08-2005 09:28 AM
Your file attachment limits Brent ME Site Help & Announcements 38 04-17-2005 01:50 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
03:27 PM
