02-10-2013, 08:05 PM
#1 | | Registered User
| used gt 40 heads for a 95 mustang gt
Will it be worth to buy some of these heads for my gt? How about the intake with it
__________________ |
02-10-2013, 08:32 PM
#2 | | Registered User
Depends on how much. Are they the X or P? Are they going to need work? Any idea if they need Valves, springs, or milled? How many miles are on them? You will need an intake to get the most out of them too.
2011 GT Premium Black on Black, Eibach Sportline, Eibach Camber Bolts, BMRAdjustable Pan-hard bar, 19 x 9 Replica Boss 302 Laguna Seca, 275/35-19, GT/CSFront Fascia, C&L CAI, SCT SF3 w/ Bama Tune, Bassani Axle backs.
02-10-2013, 08:44 PM
#3 | | Registered User
79 g and good condition theysaid ---------- Post added at 08:43 PM ---------- Previous post was at 08:43 PM ---------- 600 for both ---------- Post added at 08:44 PM ---------- Previous post was at 08:43 PM ---------- Whats the difference from X and p
02-10-2013, 08:52 PM
#4 | | Registered User
Aluminum versus cast iron.
Did they come aftermarket or from an explorer? 600 not a bad price for used if they do not need any work. Hard to tell if they are good though without them being looked at by a professional. Are they off the car already?
02-10-2013, 08:58 PM
#5 | | Registered User
I'm doing a gt40 build right now. I was told by my machine shop: ported and polished heads with stiffer springs, ported and polished intake, and a Trick Flow stage 1 cam, an I'd be making about 275 RWHP. I have all supporting mods though. (24lb injectors, 65mm TB, 90MAF, etc...)
02-10-2013, 08:59 PM
#6 | | Registered User
It from s junk yard
02-10-2013, 09:02 PM
#7 | | Registered User
Stock gain is gonna be about 45 crank hp, give or take. If you're gonna do a cam, upgrade the springs. It's worth it to port and polish. The Trick Flow kit is only about 300 +/- ish RWHP.
#8 | | Registered User
I guess it's been awhile since I looked a prices for heads for my 95. In the Dallas area used gt40p heads are going for 300. I think you could do better.
02-10-2013, 09:06 PM
#9 | | Registered User
It from s junk yard
02-10-2013, 09:09 PM
#10 | | Registered User
| Quote:
Originally Posted by rick9550 I guess it's been awhile since I looked a prices for heads for my 95. In the Dallas area used gt40p heads are going for 300. I think you could do better. | +1. I am 60 miles south of DFW. P heads are even cheaper, and serve the same purpose, with slight header clearance issues. I bout my full set up off Craigslist at a damn good price. Just doin machine work to get all I can.
02-10-2013, 09:12 PM
#11 | | Registered User
| Quote:
Originally Posted by nickvigil It from s junk yard | They probably have a 30 or 90 day warranty. If they are bad you are just out the time and gaskets. ---------- Post added at 10:12 PM ---------- Previous post was at 10:10 PM ---------- If you are doing the swap yourself anyways
02-10-2013, 09:20 PM
#12 | | Registered User
Ya i am . What cam would be the most hp gain with Trick Flow Intake and the GT 40 heads
02-10-2013, 09:35 PM
#13 | | Registered User
| Quote:
Originally Posted by nickvigil Ya i am . What cam would be the most hp gain with Trick Flow Intake and the GT 40 heads | That's kind of a loaded question.  . The 94-95 computers do not like major mods. If you plan to change it out or get a custom tune than you options open up more. I had edelbrock performer heads and performer RPM intake (basically the same as gt40x and cobra intake) with a b cam and could barely keep it from dying at the stop lights. It certainly woke her up though and the lope sounded great. No problem pulling on the new edge GTs with that set up. I also had to worry about emissions too.
02-10-2013, 09:36 PM
#14 | | Registered User
Guess I might just be talking to hear myself talk on this thread....*crickets say: chirp, chirp, chirp...*
02-10-2013, 09:40 PM
#15 | | Registered User
what is the best way to tune
02-10-2013, 09:42 PM
#16 | | Registered User
| Quote:
Originally Posted by 91notchback Guess I might just be talking to hear myself talk on this thread....*crickets say: chirp, chirp, chirp...* | Lol.  . I'm new... Do you need stiffer springs with the stage 1 cam? What's the lift and duration?
02-10-2013, 09:44 PM
#17 | | Registered User
can I just get the top end off s cobra
02-10-2013, 09:54 PM
#18 | | Registered User
Yup. Grab the injectors and computer while your at it. You will still need a cam at least to get the power out of that set up. The cobra cams are a bit more aggressive than the GTs but not even close to a decent aftermarket. ---------- Post added at 10:54 PM ---------- Previous post was at 10:53 PM ---------- And...if you get the injectors you will need a new Mass Air sensor.
02-10-2013, 09:55 PM
#19 | | Registered User
| Quote:
Originally Posted by rick9550 Lol.  . I'm new... Do you need stiffer springs with the stage 1 cam? What's the lift and duration? | It's al good bro. Stiffer springs are recommended with these heads as the explore cam was VERY weak. I would go e303 or TFS stage 1. Remember: power is the combination of al parts working together.
#20 | | Registered User
K thanks for the info
02-10-2013, 10:00 PM
#21 | | Registered User
| Quote:
It's al good bro. Stiffer springs are recommended with these heads as the explore cam was VERY weak. I would go e303 or TFS stage 1. Remember: power is the combination of al parts working together. | I second that!!
02-10-2013, 10:02 PM
#22 | | Registered User
Hope we were a combo of good info for you bud!
