tranny problem - Mustang Evolution
Old 02-11-2013, 10:29 PM   #1
nickvigil's Avatar
Region: Utah
tranny problem
At high rpms its hard to engage second gear
nickvigil is offline   Reply With Quote
Old 02-11-2013, 10:58 PM   #2
How high rpms are we talking? Is 2nd your only problem gear?
keaton5.0 is offline   Reply With Quote
Old 02-12-2013, 12:00 AM   #3
nickvigil's Avatar
Region: Utah
Sometimes third 3 g or nore
Old 02-12-2013, 05:19 PM   #4
nickvigil's Avatar
Region: Utah
Any pointers?
Old 02-12-2013, 11:25 PM   #5
Either syncros or clutch adjustment. Have you tried lifting up on the pedal to.see if you can get a click out of the stock adjuster?
Old 02-13-2013, 01:13 AM   #6
nickvigil's Avatar
Region: Utah
Running or off
Old 02-13-2013, 01:37 AM   #7
Billymich's Avatar
nickvigil, this is exactly what I told you to do in the other thread, lift up on the clutch pedal it may click as it adjusts. running or off it makes no difference... obviously be in neutral
Old 02-13-2013, 01:52 AM   #8
nickvigil's Avatar
Region: Utah
Well obviously it didnt work billymich
Old 02-13-2013, 04:01 AM   #9
Xaperez100's Avatar
Most likely could be your throw out bearing. Try driving it and shifting into gears without using the clutch. Meaning you'd have to match rpms. Idk what rpms you'd have to be at on your stang. But mine is around 2.5
But yeah. It's most likely your throw out bearing that's what my problem was. But I couldn't get into any gear.
Xaperez100 is offline   Reply With Quote
12:40 PM
