Transmission issue - Mustang Evolution
Old 02-12-2013, 07:47 AM   #1
Cblackstang's Avatar
Transmission issue
So I just got a 95 GT a couple weeks ago and in between 1st and 2nd ( this is a 5 speed) I engage the clutch and the gears grind, the only way it shifts smoothly is if I let the RPMs come way down...what do you guys think possible synchro?
Cblackstang is offline   Reply With Quote
Old 02-12-2013, 05:25 PM   #2
nickvigil's Avatar
Region: Utah
I have the same problem no answers on mine either
nickvigil is offline   Reply With Quote
Old 02-12-2013, 06:13 PM   #3
Billymich's Avatar
try pulling up on the clutch pedal, also when its cold out you have to shift firmly and smooth for 1st-2nd
Old 02-12-2013, 07:55 PM   #4
nickvigil's Avatar
Region: Utah
The clutch has full peddle no play.at all it is like u dont push the clutch all the way
Old 02-12-2013, 08:47 PM   #5
nickvigil's Avatar
Region: Utah
Any help
Old 02-13-2013, 06:04 AM   #6
Rob94gt's Avatar
try to c if it shifts smoothly in all gears when the car is not running and with the clutch pressed.
ive heard if it still is hard to shift when the car is off then it could possible could be syncos.
if it shifts smooth then it could be a streched cable or a misudjusted cable.
i had a problem with mine a while back n all i had to was adjust the cable underneath the car.
hope this helps a lil!
Rob94gt is offline   Reply With Quote
Old 02-13-2013, 09:56 AM   #7
Ewokjax95's Avatar
+1 More than likely synchros. May have bent one when you missed a gear at high rpms.
Ewokjax95 is offline   Reply With Quote
Old 02-13-2013, 11:00 AM   #8
nickvigil's Avatar
Region: Utah
I hope that's all it is
Old 02-13-2013, 01:57 PM   #9
nickvigil's Avatar
Region: Utah
K when off easy to shift ehere is tje cable
Old 02-13-2013, 08:41 PM   #10
Fiveohfox's Avatar
The cable is right next to the master cylinder. Comments to the clutch fork on drivers side of car on transmission
Fiveohfox is offline   Reply With Quote
Old 02-13-2013, 08:43 PM   #11
nickvigil's Avatar
Region: Utah
Is there an adjustment
Old 02-13-2013, 09:07 PM   #12
Fiveohfox's Avatar
You have to adjust it on the clutch fork on transmission , there may be a firewall adjuster too
Old 02-14-2013, 01:17 PM   #13
If he is talking about adjusting the pedal/clutch on a stock setup you have to lift the pedal. You should here a click if it was out. I haven't had the stock setup in a while though so I could be off.
Old 02-14-2013, 03:58 PM   #14
Fiveohfox's Avatar
No that sounds right
03:25 PM
