T-5 shifting issues - Mustang Evolution
Old 02-13-2013, 02:29 PM   #1
2300turboford's Avatar
T-5 shifting issues
Ok when I try to downshift into 3rd it won't go in but if I go to second then up to third it goes in is this the shifting fork?
Old 02-13-2013, 06:07 PM   #2
Anyone?
Old 03-27-2013, 01:45 AM   #3
Nwg20's Avatar
Having the same problem hope Sumone chimes in
Nwg20 is offline   Reply With Quote
Old 03-27-2013, 01:49 AM   #4
Billymich's Avatar
3rd gear is a bit touchy in t-5s I know its the easiest to grind in and miss shifts, not sure exactly why
Old 03-27-2013, 04:27 AM   #5
Dion11197's Avatar
Could be the shift fork, but my experience has been with the synchros going bad, third seems to be one of the gears that takes the most abuse.
Dion11197 is offline   Reply With Quote
Old 03-27-2013, 07:11 AM   #6
jdavis96gt's Avatar
Region: West Virgina
Have u tryed changing fluid
Old 03-27-2013, 10:16 AM   #7
Billymich's Avatar
Yeah, make sure you're using atf, gear oil causes issues.
Old 03-27-2013, 10:43 AM   #8
WC T5s use ATF fluid. Non WC T5s use 50w gear oil
keaton5.0 is offline   Reply With Quote
Old 03-27-2013, 10:53 AM   #9
Billymich's Avatar
It is my understanding that even the Non WC dont use gear oil that it causes seperation of the rings, but that they aren't as picky as the WC models.
Old 03-27-2013, 11:02 AM   #10
I got this straight from modern driveline, the non wc t5s were originally recommended to use dextron II atf but tremec engineers now recommend 50w gear oil. Dextron III may be used but it may effect shifting and wear. So i imagine there are plenty of people running atf in non wcs with no issues
Old 03-27-2013, 12:02 PM   #11
I ran gear oil in my last non wc trans.
11:05 PM
