Efi or Carb - Mustang Evolution
Old 02-15-2013, 10:35 PM   #1
Ronn501's Avatar
Region: Arkansas
Efi or Carb
Motor swap from a mountaineer to my fox should i go carb or keep it EFI
Ronn501 is offline   Reply With Quote
Old 02-15-2013, 11:48 PM   #2
Efi unless its an all out racecar then either way.
Old 02-16-2013, 07:31 AM   #3
Ronn501's Avatar
Region: Arkansas
Im goin to do EFI for quick throttle response
Old 02-16-2013, 08:46 AM   #4
My carb has excellent throttle response. You should check out the "carb vs efi" information in the useful sticky thread. It will give you a better understanding of the pros and cons.
Old 02-19-2013, 07:22 AM   #5
Tork6's Avatar
CARB has more TR then EFI theres lag in the electronics but it all depends on what u put in to it aftermarket wise as in , but CARB is the way to go for off the line if u got power
Tork6 is offline   Reply With Quote
Old 02-19-2013, 12:40 PM   #6
Billymich's Avatar
I'd disagree, I think that a proper EFI setup will have less lag (and more power) any day of the week at any RPM range. Carbs are just cheaper up front.
Let me clarify, I have nothing against carbs I just think that at the end of the day, EFI is less expensive in the long run, easier to tune, has more potential, makes more power and is more driveable. Also a good understanding of EFI will benefit you more in motorsports over your lifetime.
Old 02-19-2013, 07:21 PM   #7
Sgt_Syke's Avatar
Efi will be better for fuel economy, drive ability in different altitudes, and better idle control ( cold starts)...carbs are more finicky and require a little more patience and knowledge.
Sgt_Syke is offline   Reply With Quote
05:47 PM
