#18 fuse keeps blowing - Mustang Evolution
Old 02-16-2013, 06:20 PM   #1
Region: Nevada
For some reason my #18 fuse keeps blowing. None of my dash gages work with exception for the odometer. As soon as I replace the fuse with the required 15 amp fuse it blows the minute I turn the igniton. I decided to place a higher amp fuse just to see what the thresh hold was and I got to a 30 amp without it blowing when I turned the ignition. However, the second i push on the gas it blows.
Acording to my chilton book #18 circuit controls the Warning Indicator Lamps, Throttle Solenoid Positioner, Low Fuel Module, Dual Timer Buzzer, Tachometer, Engine Idle Track Relay, and Fluids Module Display
Any common faults I need to look at? Any ideas would help. Thanks
NFLjunkeez is offline   Reply With Quote
Old 02-16-2013, 06:25 PM   #2
Foxtrot's Avatar
Start checking grounds
Foxtrot is offline   Reply With Quote
Old 02-16-2013, 06:35 PM   #3
Region: Nevada
I've checked the ground behind the intake manifold and the one off the starter solenoid and both were nice and tight, free of corosion. I am not a mechanic by any means. I'm trying to learn as I go as I really want to know how to repair my car when needed. So sorry if I seem ignorant.
Old 02-17-2013, 07:28 PM   #4
rick9550's Avatar
I think what foxtrot was getting at was grounds under the dash like you would see for the radio, cig lighter ect. I would start looking for stray wires under the dash that might be spliced, frayed or cut as well.
2011 GT Premium Black on Black, Eibach Sportline, Eibach Camber Bolts, BMRAdjustable Pan-hard bar, 19 x 9 Replica Boss 302 Laguna Seca, 275/35-19, GT/CSFront Fascia, C&L CAI, SCT SF3 w/ Bama Tune, Bassani Axle backs.
rick9550 is offline   Reply With Quote
Old 02-17-2013, 07:31 PM   #5
deadsp0t's Avatar
Do you have an aftermarket stero? Maybe the constant is tied to one of those circuits and is grounding out..
That's unimpressive
Old 02-22-2013, 10:08 PM   #6
The420fox's Avatar
Yea if you put in an after market stereo you might hooked something up wrong , forgot a cable or a ground could have came loose that would be the first place I check then from the fuse box to various connection points ...check the simple stuff first but it sounds like there is a short in a wire somewhere if you messed with any of the wires installing something I'd check there first and double check your work.I messed up my stereo install kept blowing a fuse and my dash and ac lights would go out it was a full day of figuring out what was wrong taking off my dash and what not it ended up being my wiring mistake took couple min to fix. Well lesson learned :/ I'm new to most of this too
The420fox is offline   Reply With Quote
04:34 AM
