Help with emissions delete - Mustang Evolution
Old 02-17-2013, 02:05 PM   #1
Sgt_Syke's Avatar
Hey, I'm trying to figure out how to delete my emissions. I have smog pump and lines to heads and exhaust off. I know I will need a shorter belt. What I don't know is where all the vacuum lines tee up on passenger side, there are a couple of small electrical connectors, I don't know what they are or if I can get rid of them. Ice been looking at the T-moss diagram, but it doesn't really make sense to me. Some of the manifold vac lines I had weren't even connected, Pcv didn't have a hose on it either. Any insight is appreciated.
Sgt_Syke is offline   Reply With Quote
Old 02-17-2013, 06:19 PM   #2
Billymich's Avatar
PVC isnt emissions related. I had a thread called 'EGR' afew days back on the same subject. find it
Old 02-17-2013, 07:42 PM   #3
91notchback's Avatar
Unplug every connector that goes to your smog. I did this, and mine ran beautifully! I deleted mine cause of vac leaks as well. +5.0!
91notchback is offline   Reply With Quote
Old 02-17-2013, 07:48 PM   #4
Sgt_Syke's Avatar
I read that one, my question is what are the components on pass side fender (the electrical connectors) can they be pulled?
Old 02-17-2013, 08:38 PM   #5
Here is everything that can be removed. Non win the second pic can. Hope this helps!!
ID:	91543   Click image for larger version
Old 02-17-2013, 08:38 PM   #6
*none in. Sorry man!
Old 02-18-2013, 12:06 PM   #7
Sgt_Syke's Avatar
Thanks, that helps a bit. If I unplug those (I'm not sure what the parts they are plugged into are...i think the top is egr vac regulator) then I can pull the pieces off the strut tower wall and cap all the vac lines? Also if I do that can I leave my egr on tb and then cap it's vac line? This is what I'm looking at, looks like the connectors you showed.
Thanks again!
Old 02-18-2013, 12:56 PM   #8
Billymich's Avatar
Can the charcoal canister come out too>?
Old 02-18-2013, 03:39 PM   #9
Sgt_Syke's Avatar
The canister can come out also...I'm leaving mine in for now though.
Old 02-18-2013, 05:52 PM   #10
Yes. You can get rid of all that and cap the vac lines. You will need this to plug into the port where your egr goes: http://www.rjminjectiontech.com/products/egr-eliminator. And this to cover the hole left when you remove your egr: http://www.rjminjectiontech.com/prod...-egr-block-off.
Old 02-19-2013, 07:05 AM   #11
Tork6's Avatar
I took off all smog crap as well .. New intake and carb and all AC lines just need to take out AC unit and runs better then ever i have a few pics i can upload or send to your email just let me know about to install new custom made upper cold air intake and MSD
Tork6 is offline   Reply With Quote
Old 02-19-2013, 12:43 PM   #12
Billymich's Avatar
Hey I'd really appreciate that! send me it in a PM?
Old 02-19-2013, 02:50 PM   #13
Sgt_Syke's Avatar
Cool thanks, what would happen if I left egr bolted to tb but capped its vac line, would it read always open?
Old 02-19-2013, 02:56 PM   #14
From my understanding: yes. Because it would no longer be serving the purpose that the computer would be searching for.
---------- Post added at 04:56 PM ---------- Previous post was at 04:52 PM ----------
Sorry for any confusion. I meant: it would be running in cold loop and throwing codes.
Old 02-20-2013, 02:42 AM   #15
93slowstang's Avatar
Not for the egr, once it doesn't pick it up after a few key cycles it takes it out of the equation. It will leave the CEL on, but you can either make the relay to shut it off or if you have a tune it will **** it off as well.
Old 02-20-2013, 08:48 AM   #16
Cool. Didn't know that!
Old 02-20-2013, 09:06 PM   #17
Originally Posted by 93slowstang View Post
Not for the egr, once it doesn't pick it up after a few key cycles it takes it out of the equation. It will leave the CEL on, but you can either make the relay to **** it off or if you have a tune it will **** it off as well.
Why is it blocking out shut...? Lol
Old 02-21-2013, 03:39 AM   #18
You sure the auto correct didn't change the u to an I? Lol
Old 02-21-2013, 05:08 AM   #19
Quite positive. my phone still doesn't recognize it as a word so who knows. Lol it's showed up after I edited one of them.
Old 03-01-2013, 05:35 PM   #20
94GT302's Avatar
"Make the relay to shut it off"? please explain. 94gt
94GT302 is offline   Reply With Quote
Old 03-01-2013, 05:38 PM   #21
Meant to say resistor but here's a diagram for you.
12:54 PM
