cobra intake swap - Mustang Evolution
Old 07-17-2008, 07:48 PM   #1
cobra intake swap
I just got a 95 gt that has a bbk cold air intake and shorty headers with a magniflow x pipe and mufflers. I got a line on an intake(upper and lower) from A 93 cobra and was wondering if it could be swapped to my 95. I hate to ask but this is my first stang and I just wanna make sure it can be done before i get it and what will I need to make it work. I wanna thank any and every one for any help they can offer. Thanks again.
95stang_gt is offline   Reply With Quote
Old 07-18-2008, 01:17 AM   #2
Re: cobra intake swap
Yes it can be done with the use of an elbow or you can switch over to the fox style tb (this will take a lil more doing) I would recommend running an intake designed for the 94-95.
Benjytps is offline   Reply With Quote
Old 07-18-2008, 06:57 AM   #3
^ by elbow he means an adaptor for your throttle body~ to intake area. While you are at it you REALLY should do the heads/cam (not just an out of the box e303 cam either...) and you will see great power gains.
Old 07-18-2008, 12:46 PM   #4
I guess i could save up some more coin and do it all. What would you suggest as far as a cam and which heads. Thanks.
Old 07-18-2008, 01:06 PM   #5
trickflow stage 1&2 cams are very nice as well as thier heads
SimplyOrange is offline   Reply With Quote
Old 07-18-2008, 02:01 PM   #6
im not an expert on the 5.0 engines as some are I just know heads/intake/cam should be done at the same time to save you some install costs. let the 5.0 guys have at it to tell you combo details.
Old 07-18-2008, 09:27 PM   #7
decide what you want to do/make with the car as far as HP and as far as performance and make you a plan from there. Decide what et's you are wanting if you are into drag racing and build your combo from there.I wouldnt suggest sticking the e-cam in unless you are just going to stick with the stock e7 heads. The e-cam is a good replacement but its an antique grind and there are far more superior cams on the market for a comparable price.
Old 07-19-2008, 10:45 PM   #8
Scut95's Avatar
Trick flow makes a great top end kit that has upper and lower intakes, timing set, rocker arms, heads, cam, gaskets, and i think even the push rods.....you need to get lifters. All the parts are made to work together and you will see a nice power gain....summit and jegs have the kit so you can take a look at it.....its like 2500 but its a good deal
Old 07-21-2008, 02:38 PM   #9
If you are going with an entire top end kit you may want to consider Anderson also, they have a top end kit that makes awesome power with the trick flow heads and an anderson cam combo.
Old 07-21-2008, 05:40 PM   #10
I was thinking about the e cam. What would be a better cam though? I have a goal of around 300 to 350 hp. But I am in no hurry and have a small budget thats why I was gonna just get the cobra intake and a cam for now. The car is already pretty quick with whats already on it, I just want a little more. Thanks again
Old 07-21-2008, 07:08 PM   #11
Scut95's Avatar
the e-cam is ok but there are better cams out there to run.....I've heard bad things about comp cams so I would stay away from them
Old 07-21-2008, 09:15 PM   #12
I would recommend the tfs stage 1 over the e-cam. If all you are going to do is cam and intake then stick the TFS stage 1,cobra intake 65mm Tb,70mm mass air,24lb inj. and a real tune. You need to budget for a tune when you install your cam because there is a good chance you will have idle issues with the car.you can make 300 hp fairly easliy with a well thought out plan and smart buys.GOOD LUCK and if you want I can give you a combo that we are running right now on a car and making in the 300hp range with very good street manners.
Old 07-22-2008, 05:10 AM   #13
Yeah I would like to use a set up that has been tested and works good on the street. I may have some trouble getting a real tune since there are no performance shops up here in alpena MI. Thanks again for all the help.
Old 07-22-2008, 05:17 PM   #14
We can design you a setup to get you what you want and we can build you a tune for it as well. We offer tech support for the tune so you can datalog and we can make changes to the tune to get it spot on.
Old 07-22-2008, 05:40 PM   #15
That sounds great! As soon as I am able to gather up some coin I will be getting intouch withyou and go from there. Like I said before I am lookin for around 300 to mabey 325( my buddy has a ws6 trans am and he kinda beats on me a bit). Thanks again.
03-04 cobra automatic swap rinfield2004 1996-2004 Mustang GT 9 07-01-2010 07:27 PM
95 - 99 head and intake swap kack85 Pre-2005 V6 Mustang 2 04-26-2009 09:21 AM
Cobra R swap???? jaircuevas101 Pre-2005 V6 Mustang 11 06-11-2008 07:44 AM
v-6 to cobra swap jimmy_beaner 1996-2004 Mustang GT 30 08-11-2005 08:38 PM
Intake and head swap!?!? JERIC Pre-2005 V6 Mustang 6 09-13-2004 06:48 PM
12:56 PM
