Cobra Intake - Mustang Evolution
Old 02-19-2013, 03:26 PM   #1
87mustangGT's Avatar
Cobra Intake
Im getting a good deal on a cobra upper and lower so just wanted to make sure my plans will work. I planning on a 70mm tb, 24# injectors and port the intake as well. Any suggestions (car is a daily driver with no serious mods) thanks
87mustangGT is offline   Reply With Quote
Old 02-19-2013, 03:28 PM   #2
91notchback's Avatar
Your plans will definetly work! Nice setup. I would bolt up a set of 1.7 rr if you could swing it. $150 at LRS.
91notchback is offline   Reply With Quote
Old 02-19-2013, 03:29 PM   #3
Nicee i will look into that as well! How much hp do you think ill gain?
Old 02-19-2013, 03:29 PM   #4
They will raise your cam lift from .443 to .476.
Old 02-19-2013, 03:35 PM   #5
Also: you will need a MAF calibrated to your injectors. Try to pick up one that is at least 5mm bigger than your tb to create a "funnel" effect. :good
Old 02-19-2013, 03:41 PM   #6
I dont have MAF the cars an 87. Thanks for the advice man
Old 02-19-2013, 03:47 PM   #7
deadsp0t's Avatar
Doing a MAF swap before doing the other work is recommended for sure..
That's unimpressive
Old 02-19-2013, 03:49 PM   #8
Billymich's Avatar
not recommneded. Required. got look at fiveologyracing.com
Old 02-19-2013, 03:56 PM   #9
Boomdizzle's Avatar
In all honesty you won't see any difference in the setup without upgrading to MAF. Your car will probably run worse. Speed density uses a preset table to determine A/F ratio and doesn't take advantage of any increase in intake air. Definitely get a MAF setup. You'd probably see a 20-30 rwhp increase with the new intake, tb, and MAF.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 02-19-2013, 03:57 PM   #10
Thanks for stepping in guys. Didn't even think to ask MAF or SD.
Old 02-19-2013, 04:26 PM   #11
What does a MAF install require ive heard that you have to redo the whole front of the wiring harness?
Old 02-19-2013, 04:31 PM   #12
Billymich's Avatar
Old 02-19-2013, 04:37 PM   #13
Good information thanks
10:43 AM
