throttle body ? - Mustang Evolution
Old 07-21-2008, 02:56 PM   #1
wvstang5.0ho's Avatar
Region: West Virgina
throttle body ?
Ok a buddy just bought a 95 GT 5.0 5 speed pretty nice car, he is wanting to change the throttle body on it. he's been looking at the Ford Racing TB's, what is the stock size on them and what is a good one to upgrade to, he is all stock except for exhaust, UDP's, and CAI. Also does the MAF sensor need to be changed when going with a bigger TB?
wvstang5.0ho is offline   Reply With Quote
Old 07-21-2008, 03:50 PM   #2
Re: throttle body ?
Its best to change the mass air too.I like the BBK products but there are plenty different ones to choose from. The frpp products are nice,edelbrock, and even the professional products.For a stock head,cam combo Id run a 65mm tb but if he is going to be doing heads and cam then Id run a 70mm,75 if going forced induction on heads and cam.
Benjytps is offline   Reply With Quote
Old 07-21-2008, 03:52 PM   #3
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: throttle body ?
im running edelbrock 70mm tb
Cajun JungleBoy is offline   Reply With Quote
Old 07-21-2008, 05:47 PM   #4
Re: throttle body ?
Ok so what is the stock size ?
Old 07-21-2008, 06:54 PM   #5
1234's Avatar
Re: throttle body ?
60 or is it 55?
Old 07-21-2008, 07:05 PM   #6
Scut95's Avatar
Re: throttle body ?
stock for a 95 is 60mm.....and they went up to a 65mm when they did the PI heads on the 4.6
Old 07-22-2008, 02:29 AM   #7
Re: throttle body ?
ok so if 60 is stock, if he went to a 70mm would the MAF sensor need to be changed as well or would he be fine running the stock one till he got the funds for the better MAF sensor.
Old 07-22-2008, 01:10 PM   #8
1234's Avatar
Re: throttle body ?
It will run fine. It would run better with a maf and a tune.
Old 07-22-2008, 01:34 PM   #9
Re: throttle body ?
what do you meen by tune ? tune-up or a tuner ? if tuner what is a good one to get ?
Old 07-22-2008, 02:24 PM   #10
1234's Avatar
Re: throttle body ?
Tuner and i would have to say the sct programmer
Old 07-22-2008, 05:13 PM   #11
Re: throttle body ?
Give us a call and we will build you a tune for the car. You can run the stock mass air but it a larger would be the best choice. We can build you a tune for the car that will take care of any idle issues you may have and we can modify the tune as you add more mods to the car.A dyno tune would be the best choice but not necessary until the mods are complete. It would be a waste of money to dyno tune the car for a TB change or even a mass air change, i would recommend you wait on the dyno tune until all the mods are complete.
Old 07-22-2008, 05:18 PM   #12
1234's Avatar
Re: throttle body ?
Benjy do you make tunes for all mustangs?
Old 07-22-2008, 09:05 PM   #13
silverstangboy's Avatar
Re: throttle body ?
I would consider accufab on the throttle deal. just got one myself. it is nice.
93 mustang notch
~450hp 331 stroker - Sold
Old 07-23-2008, 03:26 AM   #14
Re: throttle body ?
thanks Benjy for the reply can I get a # and good time to call.
Old 07-23-2008, 09:45 AM   #15
Re: throttle body ?
225-622-5328
225-931-0458
You can call later on this evening around 4:30 5:00 area and Ill let you talk directly to our lead tuner.
Old 07-23-2008, 04:06 PM   #16
Re: throttle body ?
225-622-5328
225-931-0458
I'll give a call Thursday, thanks
Old 07-29-2008, 10:48 AM   #17
jthorn9's Avatar
Re: throttle body ?
Save the money on the TB, they will not yield that much power. For a stock car you should run 65mm, 70mm for mildly moded, and 75mm on highly moded or F/I applications.
Also, tuners such as the X Cal and Diablo will not work on our EEC IV ECUs. The only tuning systems availible that will is the PMS, by Anderson Motorsports, and the Tweecer RT. ACT also makes an ECU, however it's extremely expensive.
If I were him I'd invest my money into gears, they're a little more expensive than a TB, but a much better investment.
jthorn9 is offline   Reply With Quote
Should i get a throttle body? blackonblack Pre-2005 V6 Mustang 21 12-07-2009 07:21 AM
throttle body kingboy23 2005-2010 Mustang GT 7 05-06-2008 06:31 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
Throttle Body Scut95 1979-1995 Mustang GT 4 07-01-2005 10:50 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
09:40 AM
