Shocks & Struts - Mustang Evolution
Old 07-22-2008, 04:29 PM   #1
wvstang5.0ho's Avatar
Region: West Virgina
Shocks & Struts
Ok Im looking to change my worn out shocks and struts here soon on my 94 GT and want some info on what to get. I'm staying stock (not lowering) cause I wont beable to get in my driveway with out draging. So Im looking for something a little better than stock. Thanks for any help on this you can give.
wvstang5.0ho is offline   Reply With Quote
Old 07-22-2008, 05:16 PM   #2
1234's Avatar
Re: Shocks & Struts
Koni, tokico, kyb not too expensive but still damn good
Old 07-22-2008, 06:12 PM   #3
Scut95's Avatar
Re: Shocks & Struts
+1 to all the above
Old 07-22-2008, 09:22 PM   #4
bbunt302's Avatar
Re: Shocks & Struts
Bilsteins. Expensive for a reason.
Scary stuff.
Old 07-22-2008, 10:12 PM   #5
Re: Shocks & Struts
i believe bilstein sells a complete set for the front and rear, that would be what i'd go with.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 07-22-2008, 11:41 PM   #6
Y2E0L0L5OGWT's Avatar
Re: Shocks & Struts
It also depends on what you are looking to get from them...if youre not going to be doing much racing of any type, then you really don't need adjustables so that rules out Koni's and Tokico D-specs...
I would probably have to suggest the Bilstein's as Bbunt said for one of the better, if not the best, fixed systems out there...
Old 07-23-2008, 06:46 AM   #7
Re: Shocks & Struts
the valving needs to be matched to the springs you have~ so buying certian shocks/struts wont do much without stiffer springs, just fyi.
Old 07-23-2008, 11:27 AM   #8
1234's Avatar
Re: Shocks & Struts
But at the same time they also make a stock setups for most cars.
Shocks/Struts for H&R's? SSgt Dan 1996-2004 Mustang GT 2 03-06-2010 05:58 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 09:34 PM
c-springs & mm plates....ok w/o shocks struts? tedness Pre-2005 V6 Mustang 4 06-27-2005 11:03 PM
Shocks..struts Exit_In_Red Pre-2005 V6 Mustang 6 12-01-2004 10:33 PM
11:32 AM
