Help needed making up my mind - Mustang Evolution
Old 02-25-2013, 01:09 PM   #1
Outlawmack's Avatar
Ok here's the deal. I have a 95 gt 5 speed that I want to make a real healthy street car 425475 rwhp. Something that I can drive everyday and run high 11's low 12's not overly done where you have to buy race gas and not practical.
Option 1. 306 with a turbo or supercharger Option 2 Stroker motor with the factory 302 Option 3 351w swap (but I know that would leave me to wanting more than what is needed)
I don't want to spend 10-15 grand on the motor. That would be a great down payment on a '14 gt What are your thoughts and the setups that your using with hp numbers and times if you have them?
Outlawmack is offline   Reply With Quote
Old 02-25-2013, 01:32 PM   #2
That is pushing the limit of the stock block. Plenty of people are running 450+ to the wheels on a stock block but not cheaply. Any route you take to get that much power you will need to factor a dyno tune into your budget. When you factor in supporting mods, bigger fuel pump, injectors, regulator, clutch, and when the T5 thats rated at 300lbs of torque fails from double the amount its rated at you will have to invest in an upgraded trans. I dont mean to discourage you i just dont see if happening with less than 10k. A good set of heads alone will run in the $1500 range and add another 1500-2000 for a decent turbo kit. If i had to pick a route id say 351 swap. More cubes equals more power and the 351 blocks are stronger than the factory 302s.
keaton5.0 is offline   Reply With Quote
Old 02-25-2013, 01:44 PM   #3
Outlawmack's Avatar
I meant 10-15 grand on the motor alone. I know the trans won't hold up and ill need a bigger fuel system, axles and gears, suspension. I want to do everything for under 20. 15 if possible
Old 02-25-2013, 01:52 PM   #4
Then i think you will be just fine any route you go. A 306 with a good h/c/i setup will put your over the 300rwhp level. Then with a well tuned turbo or supercharger setup will push you past 400. But if you decide to stay with the 302 block i would stroke it out to a 331 and you will hit 400+ a little easier. DSS racing sells great stroker kits for good prices.
Old 02-25-2013, 02:02 PM   #5
Outlawmack's Avatar
Do you think a 331 would live for awhile under boost? Some people say either stroke or fi. But haven't seen anyone say both
Old 02-25-2013, 02:07 PM   #6
Outlawmack's Avatar
Keaton5.0. Thanks for the dss racing info. I just checked out their site.
Old 02-25-2013, 05:40 PM   #7
v.j. fowler's Avatar
306 with a blower will put out some good power.
v.j. fowler is offline   Reply With Quote
Old 02-25-2013, 05:48 PM   #8
Billymich's Avatar
Or you could build a really stout 331 with a main girdle and balanced AND forged internals, with a 150 nitrous oxide boost when you need it =D to be honest I don't know what it would cost, but you would have a very manageable street car that would put down some decent 1/4 mile times. Any thoughts guys>?
Old 02-25-2013, 05:49 PM   #9
The Helion Twin Turbo kit on AM is like 7k... Might be a possibility.
Old 02-25-2013, 08:14 PM   #10
Outlawmack's Avatar
I was looking on their site. But it shows 96-04 for the turbo kits. They do have the supercharger kits for the 94-95 from $3200-4900
Old 02-25-2013, 08:23 PM   #11
WhiteCobra94's Avatar
My brother has a stock block stroked with a forged 347 , AFR 225 heads, Holley SystemMax II intake with a Anderson Cam and he dynoed at 445rwhp / 468tq and that's all motor !!
Old 02-25-2013, 08:25 PM   #12
Outlawmack's Avatar
^nice. Does he have any track times? Just curious Also where about in PA?
Old 02-25-2013, 08:27 PM   #13
No track times yet , we are taking his and mine this season .
I'm in west Chester, he is in King Of Prussia, his car was dynoed at "2nd Street Speed "
Old 02-25-2013, 08:31 PM   #14
Outlawmack's Avatar
That's cool. I'm about 65 miles north of you guys
Old 02-25-2013, 08:32 PM   #15
Towards like Allentown or more west
Old 02-25-2013, 08:33 PM   #16
Outlawmack's Avatar
8 miles south of the pocono raceway
Old 02-25-2013, 08:38 PM   #17
Ever met Bam Margera? I had to ask lol
Old 02-25-2013, 08:50 PM   #18
I actually have and he lives like 3 miles from me , he owns a bar in west chester called the Note , and if you remember Ryan Dunn the one killed in the car crash, that was right down the street from me.
Old 02-25-2013, 08:54 PM   #19
Outlawmack's Avatar
Yeah I remember that. That was a bad wreck
Old 02-25-2013, 08:58 PM   #20
Yea it's all still chard woods
05:38 PM
