Added frustration - Mustang Evolution
Old 02-26-2013, 01:22 PM   #1
Cblackstang's Avatar
Added frustration
Just to add to my frustration I went to move me car last nite to start the rebuild and no start..I'm pretty sure it's the fuel pump..I checked the cut off button it's good and the relay by the coolant resavor and swapped them no luck..any other suggestions before I drop this tank??
Cblackstang is offline   Reply With Quote
Old 02-26-2013, 03:27 PM   #2
So I'm assuming your not getting fuel? I would check voltage at the pump first to be sure before dropping the tank.
Old 02-26-2013, 09:00 PM   #3
No fuel pressure at the rail and no pump prime
Old 02-28-2013, 03:32 PM   #4
Roguestang's Avatar
If the pump is getting power, then its gotta be a bad pump. Looks like you are building her anyways, so id invest in a better than stock pump for future power. It wont hurt! Lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 02-28-2013, 07:42 PM   #5
I have declared it as the pump being bad now it's the options of how big of a replacement pump should I get..I'm building on a budget so and ideas would be nice
Old 02-28-2013, 08:00 PM   #6
IMO most people think that getting a large fuel pump will rally benefit you. If you are going gt40 or similar build just get the 155. If you are going full aluminum then you can get the 190. But I wouldn't go larger than that unless you are planning forced induction.
Old 02-28-2013, 08:14 PM   #7
That's what I was thinking was Probly 190 i can get a 255 but I figured it wouldn't make a difference unless I get bigger lines
Old 02-28-2013, 08:17 PM   #8
Roguestang's Avatar
What dreamstang said. It wont hurt to go too big, but it could effect your gas mileage. But 155-190 is pretty common. I have a 255 but I have a blower on my car. I actually have a spare Holly (made by walbro)120 lph that I never used. But I dont have the filter sock or electrical connector with it if you are interested
Old 02-28-2013, 08:18 PM   #9
Thanks but ill Probly just go with a 155..for what I want to do it should be all I need for now
Old 02-28-2013, 08:20 PM   #10
Roguestang's Avatar
I bought mine off craigslist. Infact id say I buy 70% of my parts off craigslist. I find that if you are buying from mustang enthusiasts, that solidarity means we are good people! Lol
Old 02-28-2013, 08:35 PM   #11
Yea usually I buy everything on Craigslist and then I also sell alot of stuff on there too I found one on summit racing for 89$ doesn't sound to bad to me when auto part stores want between 93 and 120$
Old 02-28-2013, 08:40 PM   #12
Roguestang's Avatar
Yeah that sounds about right. Just double check the shipping charges. I live in Fl, and recently took a trip to Tennessee. On the way I saw a Summit store off I-75. Needless to say I stopped and almost spent my vacation between there and Bass Pro Shop. Lol
Old 02-28-2013, 09:14 PM   #13
Yup 155 will suffice for most applications.
Old 03-01-2013, 07:20 PM   #14
93slowstang's Avatar
I have a 255lph In mine and it didn't affect my gas mileage at all.
Old 03-01-2013, 07:45 PM   #15
Roguestang's Avatar
Yeah it may and may not. Mostly depends on how you drive. But that goes for any car and any pump. But I noticed a decrease with my 255.
Old 03-01-2013, 09:19 PM   #16
But you have a blower on yours as well right?
Old 03-01-2013, 09:21 PM   #17
Roguestang's Avatar
Yeah I do.
Old 04-21-2013, 12:04 PM   #18
Problem solved!! No clue what it was..there was no power to the fuel pump..somewhere from the front to back the wire is bad so I ran a switched wire back an runs good
Old 04-21-2013, 12:08 PM   #19
Roguestang's Avatar
Awesome! Glad shes back to normal!
Old 04-21-2013, 06:49 PM   #20
Now I have a leaking return fuel line..previous owner had a rubber hose rigged on the braided one..any ideas on a fix without buying the 150$ hose from LMR?
Old 04-21-2013, 09:17 PM   #21
Roguestang's Avatar
Check a junk yard? Pretty much any 5.0 up to 95' should have that hose. Or replace the whole thing and get some billet fuel rails. Just some brain storming........
01:50 AM
