speedo gear question - Mustang Evolution
Old 02-28-2013, 11:47 PM   #1
RoCoBass's Avatar
Region: Iowa
This speedo gear is from AOD, swapping in a T5. Was told could use the same gear just cut off 1/4" of shaft. Does anyone know the exact length of shaft on T5 speedo gear? Thanx in advance!
ID:	93446   Click image for larger version
ID:	93448   Click image for larger version
RoCoBass is offline   Reply With Quote
Old 02-28-2013, 11:58 PM   #2
McNassty's Avatar
Why not just get an OE one from Latemodelrestoration?
---------- Post added at 05:58 AM ---------- Previous post was at 05:57 AM ----------
They are lik $12-15
McNassty is offline   Reply With Quote
Old 03-01-2013, 12:05 AM   #3
RoCoBass's Avatar
Region: Iowa
Thats where I purchased this one from when I did the rear gear upgrade. Only difference is in color of gear & shaft length, teeth count is identical. If trim a bit off the shaft it'll be the SAME THING.... just need the appropriate shaft length.
Old 03-01-2013, 12:52 AM   #4
McNassty's Avatar
Got me, I like to do things right the first time not rig it up, maybe somebody else on here will know
Old 03-16-2013, 04:08 AM   #5
RoCoBass's Avatar
Region: Iowa
... You got me McNassty, my speedo didn't work & ended up ordering gear anyways. I should've listened. Thanx
06:08 AM
