Replaced dizzy now problems - Mustang Evolution
Old 03-02-2013, 04:33 PM   #1
Outlawmack's Avatar
Ok now I have a problem!!! Replaced the dizzy, car starts fine and idles fine. When you rev it, it misses and doesn't sound like it has much power. Also blowing a lot of white smoke (smells like magnesium or fireworks going off). I didn't get a chance to change the plugs or wires yet. Maybe tomorrow. Anybody have any ideas?????
Outlawmack is offline   Reply With Quote
Old 03-02-2013, 04:45 PM   #2
Definitely sounds like timing.
Old 03-02-2013, 05:11 PM   #3
Outlawmack's Avatar
Ill have to get a timing light and check it after I do the plugs and wires
Old 03-02-2013, 06:22 PM   #4
Billymich's Avatar
Or... you have wires to the wrong plugs... easier that you think to do lol
With 1-2 not firing correctly it may idle fine but under load will seem like you have NO power till about 3k rpm or more timing will also do this.
Old 03-02-2013, 09:24 PM   #5
Yeah you can't change a dizzy and get the timing perfect without setting it. Like mentioned make sure your wires are right and set your timing.
Old 03-03-2013, 04:29 PM   #6
mike_jay5.0's Avatar
Not uncommon to buy defective dizzy. I ran threw 4 in two years
mike_jay5.0 is offline   Reply With Quote
Old 03-03-2013, 05:02 PM   #7
sounds like you may have some other issues.
Old 03-09-2013, 08:51 PM   #8
Outlawmack's Avatar
Replaced the double platinum plugs with regular autolites and the plug wires. Car started, idled and had power with no miss. Put the timing light on and I had it at 14 degrees. Runs great, must have been a bad wire causing the problem
Old 03-09-2013, 09:27 PM   #9
Yea. Ignition switch shorts out and caused all sorts of ignition problem. Over heated coils dizzy
11:36 AM
