Installing gt 40 heads and fordracing e cam - Mustang Evolution
Old 03-03-2013, 02:32 PM   #1
Peluks90's Avatar
S ere anything I need to change like rollers.. Injectors.. Anything,,, before I put this in into a stock 5.0 any recommendations.
Peluks90 is offline   Reply With Quote
Old 03-03-2013, 05:06 PM   #2
91notchback's Avatar
Valve springs for sure. The gt40 ones are a notorious week point on those heads. Also, cams and lifters wear together. Pick up a new set of lifters also.
91notchback is offline   Reply With Quote
Old 03-03-2013, 08:03 PM   #3
I would do a timing set too.
83notcho is offline   Reply With Quote
Old 03-03-2013, 08:39 PM   #4
+5.0 the "you might as well"s have me knee deep into my build
Old 03-04-2013, 12:58 AM   #5
Peluks90's Avatar
What would u recommend I set the timing to? Or would it depend..
---------- Post added at 01:58 AM ---------- Previous post was at 01:57 AM ----------
Oh and by the way the gt 40 heads are double spring valve job has Been done and also ported
Old 03-04-2013, 03:29 AM   #6
I would start with the timing at 10* right after the install until you know everything is running good. Then you can advance it a little at a time up to 14* but going that high may require premium fuel, but well worth it imo. Just listen for pinging/detonation while driving under load.
Old 03-04-2013, 04:57 PM   #7
Peluks90's Avatar
Ok thanks guys... But I should be ok with my gt 40 heads then..? I wouldent need to change the manifold injectors any lifters stuff like its cus I'm scared that once I put the cam on it may just want to die or in the long run mess up something in the engine
Old 03-04-2013, 05:36 PM   #8
It's all what you can afford. I think that 19 lb injectors will suffice for now. You can upgrade later to 24, but will need to tune or change maf also to match.
The lifters and timing set are a really good idea when changing the cam but not totally necessary. Again its what you can budget. I just picked up a set of trickflow lifters for 120$. I use a timing gear drive instead of a chain but they are more expensive.
Old 03-05-2013, 01:14 PM   #9
93slowstang's Avatar
+1, but I used ford racing lifters for 109. I believe trickflow uses the FR brand if I'm not mistaken so either ones are a great budget choice. A new chain is cheap insurance.
Old 03-05-2013, 02:11 PM   #10
Yeah its kinda one of those things. I have tfs Pushrods and heads. May as well match the lifters. Lol
Old 03-06-2013, 12:50 AM   #11
Peluks90's Avatar
So I need to get specific lifters? Or I can get some comp cam lifters from American muscle? Or any laters will go fine Witt the stock
---------- Post added at 01:50 AM ---------- Previous post was at 01:49 AM ----------
With the stock push rods?
Old 03-06-2013, 01:47 AM   #12
You need hydraulic roller lifters, any brand you choose is up to you. I was able to use my stock pushrods, but you may want to measure what you need just to be certain.
Old 03-06-2013, 12:35 PM   #13
Peluks90's Avatar
So as long as the push rods and lifters are correct measurements everything else will fall right into place?
Old 03-06-2013, 12:39 PM   #14
Pretty much should.
Old 03-07-2013, 06:26 PM   #15
Peluks90's Avatar
What kind of cam would u recommend bro? E cam b cam? Ect ect
Old 03-07-2013, 06:31 PM   #16
If you plan in staying NA I would say the B-cam. If you plan on forced induction later on I would go with the E cam, it's a decent NA and FI cam. The trick flow stage 1 cam has a nice profile and lope to it as well.
I have the E and like its mild lope when it's warmed up but sometimes I wish it was a little choppier. The b cam and TF cam both have a decent choppy lope.
Old 03-08-2013, 08:12 PM   #17
havhammer's Avatar
I run N/A and I run the f cam with trick flow heads. Idle has a nice lump and the car has great power and pull up to about 6500 rpms.
havhammer is offline   Reply With Quote
08:44 AM
