Gt40p explorer questions - Mustang Evolution
Old 03-06-2013, 09:18 AM   #1
harryb5a4's Avatar
Region: West Virgina
So my neighbor wrecked his 98 5.0 explorer. He is selling the parts for cheap. I already have an Explorer motor complete sitting in my garage so I don't need that. I was wondering I have heard that those rear ends came with 3.55 3.73 or 4.10 gears. Does anyone know if that rear end would fit in my 88 gt. it has the original 2.73 in it.
harryb5a4 is offline   Reply With Quote
Old 03-06-2013, 09:36 AM   #2
Outlawmack's Avatar
The explorer rear axle swap is big in the jeep world. The gears will fit because its an 8.8. Most likely has 3.73 gears. There should be a tag on the diff cover that says. Or jack up the rear and spin the tire one complete turn and count how many times the driveshaft turns. Exp I tire to 4 driveshaft is 4.10
Outlawmack is offline   Reply With Quote
Old 03-06-2013, 04:20 PM   #3
I don't believe you can use the whole rear end though. I --> think its wider. That would make the tires stick out limiting tire sizes.
Old 03-06-2013, 06:45 PM   #4
I believe the spring/shock perches will be in the wrong spots and the differential i think is also off set.
keaton5.0 is offline   Reply With Quote
Old 03-06-2013, 07:12 PM   #5
The only things good are the carrier and can probably use the.driver side axle for a 5 lug conversion but would still have to get another. That is if its the right year?
Old 03-06-2013, 07:31 PM   #6
I know people do that with ranger axles but idk about explorers. The explorer should have 31 spline axles i think. It would be worth getting the differential and gears and then buy some good 31 spline axles.
Old 03-06-2013, 07:33 PM   #7
Yeah. I have only heard of rangers also. But I thought explorers were basically rangers drivetrain wise?
Old 03-06-2013, 07:58 PM   #8
The only difference i know of is the 31 splines on the explorers, which is probably why people use ranger axles. Other than the 5.0 and all wheel drive on some exploders they are the same. FX4 package rangers came with 8.8" 31 spines and 4.10s tho.
Old 03-06-2013, 08:23 PM   #9
Cool. I currently own a ranger and an explorer. lol But the explorer is an 04. I really like the fx4 package to.
« advice!!! | Newb »
11:16 PM
