Help!!! - Mustang Evolution
Old 03-11-2013, 08:07 PM   #1
87mustangGT's Avatar
Help!!!
Dont know whats wrong with my car took it out today and it stalled. Cranks and cranks has spark but the fuel pump doesn't kick on when i hit the key changed the fuel pump and checked the relays the inertia switch is good and didnt trip i even tried bypassing that please any suggestions will help
87mustangGT is offline   Reply With Quote
Old 03-11-2013, 08:43 PM   #2
maldog's Avatar
Region: Nevada
I'm not sure if that year stang has a fuel safety CB ( circuit breaker) Check your service manual or go online. it may have popped out and you will have to reset it.
---------- Post added at 07:43 PM ---------- Previous post was at 07:39 PM ----------
Found this for you.....
You might also want to check the conditon of your fuel cut off inertia (sp?) switch located in the hatchback under the interior panel towards the rear of the hatch.Its a shock sensitive button switch...if you are in an accident it pops out like a circuit breaker to cut off power to your fuel pump...if it was triggered all you have to do is push the button to reset it...You might want to check to see if there are any problems with this switch that may be causing it to intermittantly fail?
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 03-12-2013, 04:45 AM   #3
Ive checked tgat switch an even jumped it out still nothing
Old 03-12-2013, 05:11 AM   #4
Finchms's Avatar
Have u checked the relay under the drivers seat?
Finchms is offline   Reply With Quote
Old 03-12-2013, 07:23 AM   #5
Yes and bought a new one and the ecu in the passenger kick panel
Old 03-13-2013, 04:39 AM   #6
Finchms's Avatar
U make sure u getting power thru the wire coming from the ecu? U may need to start chasing wires to see if any are broken or frayed.
07:55 PM
