fuel injectors - Mustang Evolution
Old 03-12-2013, 09:14 AM   #1
lancer070187's Avatar
fuel injectors
I am almost done with my engine rebuild and I noticed that my fuel injector tips are cracked. I bored out the cylinders and upgraded the cam shaft. Would it benefit me to go wit 24 lb injectors or should I just replace the stock 19 lb the 24 lb injectors are only $5 more?
lancer070187 is offline   Reply With Quote
Old 03-12-2013, 12:52 PM   #2
With stock heads 19lbs will be fine. If you plan on upgrading the heads go 24. Make sure you get a tune or a calibrated maf to match your injectors.
Old 03-12-2013, 01:12 PM   #3
Ok thank you.
Old 03-12-2013, 02:12 PM   #4
Your welcome and good luck with your project.
03:39 AM
