HELP!! - Mustang Evolution
Old 03-12-2013, 02:33 PM   #1
Nwg20's Avatar
HELP!!
My 86 gt idles around 1500 wen warm and I hate it. It does it wen I come to a stop with the clutch In an in neutral. If I turn my flashers on the gauges jump with te flash and can feel like a miss or lil bog from the motor. I'm bout to hit autozone an need advice
Nwg20 is offline   Reply With Quote
Old 03-12-2013, 08:33 PM   #2
billygodfree's Avatar
It could be the alternator going bad
billygodfree is offline   Reply With Quote
Old 03-12-2013, 08:57 PM   #3
Boomdizzle's Avatar
Sounds exactly like an alternator that is going bad. Sorry man!
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-13-2013, 09:27 AM   #4
FLAT BLACK GT's Avatar
Have you guys ever had noise coming from the alternator? I'm In a similar boat myself. I did a stethoscope test and confirmed the clicking was from the alternator you can even feel it. I heard under drives will weaken them and mine is underdriven.
---------- Post added at 10:27 AM ---------- Previous post was at 10:26 AM ----------
Hope it works out for ya man
FLAT BLACK GT is offline   Reply With Quote
Old 03-13-2013, 09:29 AM   #5
Adogg's Avatar
^^ yea man I have heard on here Of under drive pullies giving ppl some problems
Don't hate....... appreciate
Old 03-13-2013, 12:16 PM   #6
Nwg20's Avatar
Well I got a brand new alternator 2 weeks ago cuz mine was shot. I'm not sure if it has pulleys or not it has a small cam and that's all I kno of.
Old 03-13-2013, 01:21 PM   #7
I just don't understand why your idle is at 1500rpms. I've never seen a bad alternator do that. What all modifications do you have done to it? Have you done anything lately like before this started happening?
Old 03-13-2013, 04:39 PM   #8
Nwg20's Avatar
It's more like 1300 but varies. That's the way I got it. It was a very cold night and I thought that's why it did that. But I can't figure all this out I'm new to the mustang world. I was told it sounds like it has a cam but gain not sure. I noticed today I got in it an it felt a lil restricted until the rpms got up cuz I wound it out a lil. Wen it got up there it felt like boost or sumthin liked in. Through first and second
Old 03-13-2013, 10:43 PM   #9
Hmm I've never heard of a cam doing that. Does it have an after market throttle body? Cause if it does and the alternator isn't the issue it may just need to be adjusted. There's a screw that you turn to adjust the rpms at idle and you also need to set the tps to the right voltage which may be why it's somewhat sluggish if its not set right. It needs to be set at between .9 and .99 volts, .99 being the sweet spot. At least this is what I've been told. I just recently did this with mine cause I installed a professional products 75mm and it seems to be working just fine. I don't know a whole lot myself I'm sill learning but hopefully this helps ya out.
Old 03-13-2013, 10:56 PM   #10
Nwg20's Avatar
It looks pretty stock but ill look into that an thanks. I'm also trying to figure out why wen I stab it sumtimes it backfires into the intake it sounds like
Old 03-14-2013, 12:40 AM   #11
Coreyw428's Avatar
Region: Arkansas
Is it still a speed density setup? Or has it been changed to mass air?
Coreyw428 is offline   Reply With Quote
Old 03-14-2013, 08:48 AM   #12
Nwg20's Avatar
Still speed density
Old 03-14-2013, 02:15 PM   #13
Have you checked your timing?
Old 03-14-2013, 10:16 PM   #14
Nwg20's Avatar
Would that cause it ?
Old 03-14-2013, 10:45 PM   #15
I would imagine that if your timing is off it could cause a backfire and if its missing def could be. Wouldn't hurt to grab a timing light and check it.
Old 03-14-2013, 11:56 PM   #16
Nwg20's Avatar
It never cuts out or anything just wen I fish start it if I gas it it just pops in the intake
Old 03-15-2013, 12:29 AM   #17
McNassty's Avatar
Does it have a canned tune?
McNassty is offline   Reply With Quote
Old 03-15-2013, 05:28 AM   #18
Coreyw428's Avatar
Region: Arkansas
If it has a cam in it then that's the problem, cams and speed density don't work together
Old 03-15-2013, 04:17 PM   #19
Billymich's Avatar
Check for Vac leaks.
Old 01-30-2014, 06:28 AM   #20
Dancobra75's Avatar
I've had three do that, changed the TPS on top of the throttle body, all idled as they should, worth a shot
Dancobra75 is offline   Reply With Quote
Old 01-30-2014, 06:30 AM   #21
Dancobra75's Avatar
Well, they wasn't flashing lights a stuff, the prior posts are prob on to something with the alt sugg,
04:35 PM
