HELP - Mustang Evolution
Old 03-14-2013, 02:22 PM   #1
Vazqueza90's Avatar
HELP
I just bought new door actuators for my 89 stang from LMS
My passenger door works but my driver side doesn't want to work
Vazqueza90 is offline   Reply With Quote
Old 03-14-2013, 03:14 PM   #2
mustangmania91's Avatar
Could be a bad switch and or a wire grounding out
mustangmania91 is offline   Reply With Quote
Old 03-14-2013, 03:19 PM   #3
Vazqueza90's Avatar
But the old one worked perfectly jus buzzed when it will lock
Old 03-14-2013, 03:44 PM   #4
Vazqueza90's Avatar
It has power cause when I pull it out n press the button it works great
Old 03-15-2013, 05:11 AM   #5
If it works when u pull the switch out but not when installed it sounds like the switch is grounding out
Old 03-15-2013, 09:12 AM   #6
Vazqueza90's Avatar
I put my old one back on and it works perfectly except the buzzing noise when it locks
So can it still be my switch
Old 03-15-2013, 07:29 PM   #7
Tominkc's Avatar
Send a message via Yahoo to Tominkc
Could be that when you put the switch back in its putting pressure on the wire and not letting itself contact when you push it!! Make sure that its not touching when you reinstall it!
Tominkc is offline   Reply With Quote
10:50 PM
