94 5.0 - Mustang Evolution
Old 03-23-2013, 11:34 AM   #1
Rcansawroy's Avatar
Region: Arkansas
94 5.0
Fuel pump or ccrm,,, I'm stuck should I replace both and if so should I upgrade my fuel pump? Where do I fin the right ccrm I read a thread b4 that said advance but no advance close to me
Rcansawroy is offline   Reply With Quote
Old 03-23-2013, 04:28 PM   #2
Whats the problem?
keaton5.0 is offline   Reply With Quote
Old 03-24-2013, 12:37 PM   #3
Rcansawroy's Avatar
Region: Arkansas
Fuel pump not working well I can't here it anyways!!!
Old 03-26-2013, 11:45 AM   #4
Mine was doing the same thing, and when we tested it with a mulimeter, i only had like 8 or 9 volts going to it, and none past the conectors on it. so what we did, is just hot wired it to a toggle switch. didnt feel like trying to figure out where the low volts where comming from.
94gt_Michael is offline   Reply With Quote
Old 03-26-2013, 01:07 PM   #5
Rcansawroy's Avatar
Region: Arkansas
Ok now I don't have any fire at all to the coil
Old 03-26-2013, 05:46 PM   #6
Ok we need some more info. What exactly isn't working? What do we know at this point?
From what I can tell your fuel pump and coil are both not working?
Also have you done any tests?
Old 03-26-2013, 06:05 PM   #7
Rcansawroy's Avatar
Region: Arkansas
Man I'm lost I just replace the distr. and the igniton module and still no fire as for the fuel pump it works when running a hot wire to it and it came on but car want start and there isn't any fire in the coil wire I'm not giving up just lost and as far as test I dot know any to run but koke test and I can't get anything outta the ecc nexus my battery is dead my friend is at work so can't get a jump or borrow his charger
Old 03-26-2013, 06:19 PM   #8
Hmmm. Does sound like a possible erc relay. I believe it's under the passenger seat. I also think there is another really like it somewhere on the car that you cam swap just to test. But I dont remember which one.
I would get a wiring schematic and test the relay before buying one. Make sure the relay is functioning if you can't find one to swap.
Read through this when u get a chance.
http://sbftech.com/index.php/topic,588.0.html
Old 03-26-2013, 06:56 PM   #9
94GT302's Avatar
ERC Relay?
94GT302 is offline   Reply With Quote
Old 03-26-2013, 06:57 PM   #10
Originally Posted by 94GT302 View Post
ERC Relay?
Eec
Old 03-26-2013, 10:24 PM   #11
On most fox bodies the eec relay is located in the passenger side kick panel and the fuel pump relay is under the driver seat. I think in like 92 or 93 they both were moved to the engine compartment next to the maf sensor, im not sure if that applies to sn95s tho
Old 03-27-2013, 06:34 PM   #12
Rcansawroy's Avatar
Region: Arkansas
I run a wire to the red coil wire car starts take it off and it dies plz help me out
Old 03-27-2013, 06:39 PM   #13
You need to use a schematic and trace that wire back with a meter.
Old 03-27-2013, 06:45 PM   #14
Rcansawroy's Avatar
Region: Arkansas
Everything work just runs sluggish with the wire from the coil to the battery
Old 03-27-2013, 06:49 PM   #15
so you just need a new wire then eh?
Old 03-27-2013, 07:05 PM   #16
Rcansawroy's Avatar
Region: Arkansas
Dude I wanna thank u for everything u done and will do but seriously I'm lost here
Old 03-27-2013, 07:10 PM   #17
No problem man.
Sorry if I'm being dense here, but if you have a bad wire and know which one it is what's the problem. Sorry I'm just not understanding what exactly you need. But I will do my best to help you.
Old 03-27-2013, 07:15 PM   #18
Rcansawroy's Avatar
Region: Arkansas
If and when I put a wire to the battery from the coil positive side car will fire I've replaced the dist an ignitin control module
Old 03-27-2013, 07:22 PM   #19
Ok so it works when u bypass the ignition wire on the coil? Let me look at a schematic and see I can help. But u probably are gonna have an ignition problem that needs to tracked down.
Old 03-27-2013, 07:39 PM   #20
Rcansawroy's Avatar
Region: Arkansas
Ok I'm trying to find the wire and a digram trust me I haven't driven my pony in three weeks and its killing me jack
Old 03-27-2013, 07:46 PM   #21
Ok. The wire comes from the igniton switch and through the neutral safety switch.
Here is a diagram. If you have a Haynes or Chilton they will also be located in the back. And of course some more diagrams are located in the useful sticky thread.
But your gonna have to check that wire coming out of the igniton switch. Then check that it gets through the neutral safety switch. Then of course from there to the coil. Also forgot to mention there is a fusable link in that wire to. Just start from the beginning and verify voltage one step at a time until you find the bad spot.
Old 03-27-2013, 08:06 PM   #22
Rcansawroy's Avatar
Region: Arkansas
U think control module is my problem dreamstang
Old 03-27-2013, 08:09 PM   #23
Not sure.
Old 03-27-2013, 08:24 PM   #24
Hey you got an email address so I can send you a better diagram?
Old 03-28-2013, 06:36 AM   #25
Rcansawroy's Avatar
Region: Arkansas
Rcansawroy@gmail.com and thanks bro
08:20 AM
